HV/EV and ECO mode lights on
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by R. Barre, Mar 9, 2015.
  1. R. Barre
    R. Barre Junior Member
    Los Angeles
    2015 Prius Plug-in
    Newbie question: A few days ago I noticed when I started the car that both the HV/EV and ECO mode lights were illuminated. What does that mean?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    ECO can be enabled in either HV or EV mode and it changes pedal mapping. It makes it less sensitive to gain precious control.
  3. R. Barre
    Los Angeles
    2015 Prius Plug-in
    Sorry ... I don't quite understand what "less sensitive to gain precious control" means. What's the basic difference between ECO in EV mode and ECO in HV mode?
    Thanks in advance ...
    52,889
    the difference between ev and hv is electric or hybrid mode. the difference between eco or no eco is that you have to press the pedal further in eco mode, to get the same amount of power. i believe usb meant pressure, and got zapped by spellcheck.:p
  5. bisco
    52,889
    eco also suppresses your hvac to help with mpg's.
  6. bisco
    52,889
    you have the choice of 'eco', 'norma', and 'power' modes. they all affect the sensitivity of the go pedal. they don't actually change anything, just make you press harder for power, which may or may not keep you from over pressing the go pedal and using more gas. they do affect hvac as i mentioned though. i think it's covered in the faq sticky.
    R. Barre likes this.
  7. R. Barre
    Los Angeles
    2015 Prius Plug-in
    Thanks for all that. The dealer told me that ECO meant it would stay electric until about 40mph. Is that right?
  8. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Sadly, the dealer was clueless. It's an unfortunate reality we encounter on regular basis.
  9. bisco
    52,889
    no, that's wrong. eco only does what i said. you can stay in ev up to 62 mph.
