HV-EV Button Question.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ukr2, Apr 8, 2013.
  1. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    When I go from 50 mph driving to Highway 65 mph, I have a choice to use the HV-EV Button or Not.
    If I want to save the Battery EV Miles, I can press the button and force HV mode. The PIP will use battery miles while the ICE warms up, then the ICE will replenish the EV Miles to the number when I pressed the button. I'll use more gas on the highway, but I'll have the battery miles I want to continue the trip.
    If I don't press the button, I can kick the PIP into HV Boost, or just wait until I increase my speed over 62 mph and HV Boost will start. Again the PIP will use battery miles while the ICE warms up, but then the ICE will NOT replenish the EV Miles. Instead, the PIP will continue to use some battery miles. At the end of the Highway I'll have very few battery miles, but the PIP should use less gas in the highway.
    Am I describing this correctly?
    Is there an advantage one way or the other?
  2. retired4999
    2,652
    627
    Eau Claire, Wi.
    Sounds correct to me. I guess you will have to try it both ways and see which gets you the best results. Someone will lets us know if we are wrong.
    52,854
    makes sense to me. from everything we know about the non pip, regening electricity from the ice is less efficient than using it for driving. but i don't know if that's the case with li-on. it does seem less efficient to convert one type of energy into another and then use it because there are losses in all the processes.
    babybird likes this.
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Mid 50's for MPG on the highway make using the HV/EV button a no-brainer for me, since I routinely drive well beyond battery-capacity.
    Saving electricity for when it can be better used is a nice option. The fact that the engine consumes electricity during warm-up to make it both cleaner and more efficient makes the replenishment of it later using gas is pretty much a wash.
    Adding a plug to an already well thought out system is what gives Toyota the edge over competitors. Makes you wonder when everyone will figure out why that was such a sensible approach. And memories of naysayers claiming there was no advantage of the hybrid components while cruising on the highway are still so vivid. We'll never know if they didn't have a clue of what they were talking about or were just lying to impede progress.
    Only now, as we start the second year and still only have rollout to 15 states, are we seeing some interest building. There's always first-year jitters anyway. Assumptions make it worse. There have been efforts to misrepresent too. Watching that change is reassuring... especially since we've seen other technologies stumble as time progresses.
    Long story short (guess I climbed up on the soapbox there) is that you can't go wrong just giving it a try. Not pressing the button, you'll still get great MPG. Pressing it, there's a chance of squeezing out even higher overall efficiency.
    babybird and rogerv like this.
  5. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    This all makes sense for flat highway driving. If there are some hills involved (highway speeds or not) I use HV going up and EV going down. HV for the efficient Prius design using or charging the battery as appropriate. EV for mileage and possible battery charging.
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    That's how I see it as well. I think there is negligible difference in efficiency with either method until you account for what you do at the end of your trip and whether you can plug it in. If you can't plug it in and the distance is greater than EV range I almost always use HV mode. The logic is that there may be traffic returning home that I could take advantage of lower EV speeds. If there isn't then I use it up in boost mode.
  7. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Toyota knew we'd complain if we couldn't force EV mode on and off, so they gave us the button. But there's no need to use it; the car will do fine on its own.
  8. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    Strategic use of the HV/EV button is a way to increase your actual EV miles.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I'm currently trying to figure this out myself.
    My commute is 49 miles one way and both my home and work are within 1/4 mile of a freeway on ramp/off ramp. Posted speed limit is 65mph and 60mph is the slowest I can realistically drive without causing problems with other drivers.
    So I can use EV for the short drive to the freeway then use HV mixed mode for some segment of my freeway drive then save a few EV miles for the last bit of the trip. The questions is, when do I use the freeway EV miles and do I drive just above the EV threshold so I can stay in mixed mode or do I drive at 61mph to stay in EV mode?
    I have been driving at 65mph in the hopes that I am being ultimately more efficient in the use of EV energy, by mixing it with ICE, than trying to drive at relatively high speed just on EV power.
    Once the weather stabilizes I guess I'll find out.
  10. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    I too use HV for freeway driving and keep the EV miles for low speed local streets, where the trip is long enough to need both.
    Is it more gas-efficient to (a) warm the ICE up in advance of getting on the freeway, (b) switch into HV when getting on the freeway, or (c) use EV to get up to speed and then switch to HV?
    It seems to make sense to pre-warm the engine by going into HV momentarily a minute or so before getting on the freeway. But even though I switch back to EV, the MPG indicator seems to say that the car is running in HV, not idling the ICE and using the battery for propulsion. So maybe option (a) doesn't exist (unless you're sitting at a stop light)?
  11. mmmodem
    2,732
    1,703
    Bay Area, CA
    The way I understand it, no one is smart enough to know what method is most efficient. Just because it makes sense doesn't make it so. We empirically test it out and see for ourselves. I mean, it still makes no sense to me that the heavier PiP gets 1 mpg EPA highway better than a regular Prius. But there it is.
    What makes sense to me is that b is most efficient unless the on ramp is a decline, then it's c. My reasoning is that your gas efficiency is lower when the engine is on. It makes sense the earlier you to turn on the engine, the longer it runs, and the more gas you use. You want to delay it until the last possible moment. But we won't know for sure until you test it for yourself.
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    In the interest of science I decided to let the car do it's own this this morning. I started off in EV mode as usual, hit the freeway and drove at 65mph for awhile then dropped to 60mph. I ended my 49mile trip (uphill) at 60mpg. That is pretty much what I get when I try to out think the system. My best was 61mpg and my worst when trying was 57mpg. So it almost seems like it doesn't matter. I did save 2.1 EV miles for the end of my trip when I hit city streets.
  13. markabele
    5,084
    1,782
    Nebraska
    From everything I read, it seems like if you really want the ICE to contribute you need to give it a time buffer for it to warm up. Otherwise during that warm up time the EV will do all the work. I can imagine above 62 the ICE will be doing a lot more of the work however. Someone smarter than me can verify or shoot it down. :)
    JMD likes this.
  14. mmmodem
    2,732
    1,703
    Bay Area, CA
    It's a balance. You use up more EV to aid warm up at high speeds than low speeds. But the ICE is more efficient at high speeds than at low speeds. Which one is more efficient? I'm sticking to using HV as soon as you have a straight shot to the freeway because obviously idling in HV nets you 0 mpg. If EV range exceeds the distances that you drive slow speeds, then you'll be using up EV on the freeway eventually anyway so no net loss.
    The only way I can see a warm up for HV being more efficient is when you need to save EV at the end of your trip for slow driving. Most of my commutes are 90% fast speeds or 0% fast speeds. Basically, I use the freeway for most of my trip or I don't at all. So I rarely have to save EV.
  15. markabele
    5,084
    1,782
    Nebraska
    How long does the warmup cycle in HV last? Same as a Gen3? If so that is only about 40-50 seconds if I remember correctly. Ideally you'd want to do a warmup cycle to be that amount of time when you are travelling 35ish mph or under but will be going higher directly afterwards....or stopping directly afterwards (such as before a light or stop sign right before an interstate interchange).
  16. bisco
    52,854
    in summer, it's even shorter, but in winter, it can be a couple minutes.
  17. drash
    drash Senior Member
    2,600
    1,339
    Upstate NY
    XLE AWD-e
    There are time when I wish Toyota had put in a button and/or mode for a more aggressive longer lasting EV Boost when the ICE comes on. But then I get to where I'm going and am glad I have a little more EV to get through the city. I really didn't mind driving in the winter when the I hit the Auto climate button the engine comes on with a significant boost from the battery. The computer does get use your driving and adjusts accordingly.
    iPad ? HD
  18. markabele
    5,084
    1,782
    Nebraska
    Another EV/HV button question....
    First, are you able to use cruise control while in EV. And second, if yes to the first, can you toggle between EV and HV without the cruise control kicking out?
  19. CharlesH
    2,798
    1,166
    Roseville, CA
    I haven't seen any connection between the EV/HV button and the cruise control functionality.
  20. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yes! You can use the cruise in EV.
    I don't think I have ever even tryed to go from EV to HV with cruise control on, so I don't know about this. My best guess would be it would work, but I really don't know. :unsure:
