HV/EV button (taking advantage of it)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by john1701a, May 2, 2012.
  1. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    Those are the best!
    There are so many little errand trips that require no gas. Last night we took our daughter to a medical appointment and were heading home wben we realized that we had forgotten to buy pickles to go with the grilled hamburgers we were planning to have for supper. A quick trip to the grocery store? No problem! Another gas-less trip...I love it!
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Whether one gets 2 MPGe or 1000 Mega MPGe is irrelevant, it is all theoretical folderall. What is relevant is your range that you get from the wall charge. Do you manage 10,15,25, or 35 miles ? Am presently in LV, managed to get 55 mpg on 600 mile trip, doing 65 mph. I am happy with these results. As for charging up EV while on a trip, that is more mist. I managed to save 3.9 miles and the on big downhill, I 15, got it up to 6.2 miles, however that disappeared quickly and returned to 3.9 miles. The best part and most challenging, is finding outlets to charge with at Casino Garage. So far, I am succesful !
  3. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    I'm not trying to be negative, just realistic.
    You were reporting on one-way hence its 17.2 miles and you had previously reported getting 14.1 miles of EV. So the Ice segment is effectively 3.1 miles, which is pretty small for measurements.
    My point was that there is very likely errors, such as truncation/rounding, in the fuel flow measurement systems, especially when dealing with small numbers.
    Lets look at the math (the number in the previous post were off, not sure what I did).
    17.2 miles @250 MPG = .0688 gallons used and 108MPGe overall
    17.2 miles @ 310MPG = .0555 gallons used and 117 MPGe overall
    17.2 miles @ 563MPG = .0306 gallons used and 141 MPGg overall
    Its quite possible the two days of 562mpg and 563mpg is because .03 is rounded to the small quanta of fuel the car measures so its rather consistent. (.03 is the smallest quanta of gas the Volt will report using.. )
    So the question is is this a real improvement, or were most of variance accountable from variations in trip speed, temp and driving?
    If you look at MPG you are inflating the differences, at MPGe its more modest, and at gallons used it may be within measurement errors. If you want to really show the effects of the HV/EV button you'll need to be more precise in your measurements.. maybe with an OBDII device to capture the variations in repeated experiments.
  4. mikenewmediary
    100
    24
    Bridgewater, Ma.
    Ugh, I know....I was so close...Im like " Really " ? :eek:
  5. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    150 mpg for 5 miles means you burned 5/150 = 0.033 gallons. Not a lot.
    But if you are in EV, you should be able to go 5 miles on battery, giving 999 mpg (actually infinite) and burning no gas, unless you are pushing the accelerator down hard at some point and turning the ICE on. So try to notice where that happens and see if it's avoidable.
  6. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    Well some people are lead foots.. I could care less if that SUV floors it and gets in front me. For every gallon of gas he uses for flooring it to get in front of me, my oil checks just get larger ... Yes I laugh all the way to bank in my 100+ mpg PiP.
  7. iRun26.2
    824
    169
    United States
    Very good advice!
  8. dwcerra
    dwcerra New Member
    43
    Laguna Niguel, Cali
    So just to make sure I understand you right. In your experience it's best to start the PiP and say, back out of my garage and driveway in HV Mode to warm up the engine then switched to EV. Switching back to HV when added accelleration or when going up an incline was needed, then back to EV when decending or on a level road?
  9. john1701a
    john1701a Prius Guru
    12,826
    5,306
    58
    You basically only benefit from proactively starting the engine when you know you're going to drive beyond the EV distance available.
    Otherwise, just leave it in the default EV mode.
    Even a hard acceleration will take advantage of the EV capacity when available. So, there's no need to switch to HV.
    Heater use changes the equation. But the basics still apply.
  10. dwcerra
    dwcerra New Member
    43
    Laguna Niguel, Cali
    So let me get this right, when you start your commute/drive you start off in HV mode till it warms up then go to EV mode, then again to HV when needing that extra push? I'm assuming this is mostly city driving. I've been just keeping it in EV mode until I get to the freeway then go to HV.
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    I think everyone has to look at the route they take and needs to figure out what works for them, every route will be a little different!
  12. mikenewmediary
    100
    24
    Bridgewater, Ma.
    I agree...Today, I got a wash, and fired up the engine, and it warmed, charged the ev battery .8 mi. Wash ended, ev'd to highway 1/4 mi, and then put in HV with the warm engine.
    Yesterday, fired up engin onramp to highway, ev dropped .8, and it all came back after 5 minutes.
    In my experiences, I get better mileage from not warming the engine, but i get more EV for my trip home, as I cant charge at work.
    I think its a cat and mouse game. Today, I needed the extra EV, so I warmed the engine while sitting in the car wash...
    Just passing on my experiences with the button.
    Mike
  13. john1701a
    12,826
    5,306
    58
    Not sure how you got that impression, perhaps multiple drive reports getting mixed up.
    The point is to drive in EV until you get to a location where the engine running is most beneficial, then push the HV button.
    For me, the same old commute along the slower route (55 mph max, 17.2 miles total), the point to start is 2.5 miles from home. On the way home, it's 9 miles from work. Everyone's will be different. Seasonal effect will change things too, for those of us who experience winters well below the freezing point.
  14. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Epoints,
    For the 5 miles commute:
    what was your Trip A battery miles?
    was it in EV mode or HV when driving?
    did you have the Fan on?
    what was the car temp set to?
    was it heating the car?
    was the AC on?
    If you had more that 5 miles of Battery and in EV mode, you should have made the trip with 999 mpg.
  15. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    And if speculation above is correct, 0.03 gallons may be the minimum able to be measured. So it is basically telling you that you used 'some' gas. As was said, the only way to get better MPG will be to use no gas.
  16. larryakoch
    larryakoch Junior Member
    82
    Pomona, ca
    It would be nice if there was a button on the steering wheel for HV/EV settings.
  17. iRun26.2
    824
    169
    United States
    Agreed! I've hit the 'P' button acccidentally when I wanted to toggle the EV / HV setting.
    I would also prefer to have it on the steering wheel because then I don't have to take my eyes off the road (the EV/HV button is pretty low on the main control panel of buttons, too).
  18. TPinho
    TPinho Junior Member
    New York, Westchester
    Stick a piece of adhesive foam to the EV/HV bottom, that way you don't take your eyes of the road.
  19. CharlesH
    2,797
    1,165
    Roseville, CA
    Fortunately gear shifting is under software control, so such actions don't result in any damage. Hitting "P" while moving gets translated into "N", I believe.
  20. epoints
    epoints Junior Member
    86
    Sunny Southern Cal
    what was your Trip A battery miles? not sure what Trip A battery miles? I started with 10 battery miles after complete charge
    I was in EV mode.
    did you have the Fan on? yes
    what was the car temp set to? at 68...drive at 6am and park in covered garage.
    was it heating the car? no
    was the AC on? no
    It's funny. I drove a bit less aggressive and I was getting 999 mpg. Today I pushed the paddle a bit harder and the eV indicator went off. I then got 162 mpg.
