HV Frame Cable Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Desi420, Mar 16, 2015.
  1. Mike500
    Mike500 Senior Member
    2,593
    767
    I will not discuss this issue with you, since the tools needed are beyond the scope of most "do-it-yourselfers."
    It can be done, an it would be as good as a one piece cable.
  2. ChapmanF
    18,959
    Ok - I wasn't so much interested in whether it could be done, with sufficiently esoteric tools and methods, as in whether you were advising the OP to try doing it with a butt splice and Harbor Freight crimper, without even mentioning the cable is coaxially shielded....
    -Chap
  3. Mike500
    2,593
    767
    Shielding probably wouldn't make a difference, anyway. Even a thin tin can would make a Faraday cage.
    #23 Mike500, Mar 24, 2015
  4. ChapmanF
    18,959
    Ok. On the other hand, an incompletely informed DIYer making butt splices on both legs of a floating 300 volt circuit with a grounded shield could make for some very interesting differences indeed.
    -Chap
  5. Former Member 68813
    3,524
    983
    US
    how much did you pay if I may ask? is this considered a salvage title?
  6. Desi420
    Desi420 New Member
    Chicago Burbs
    PM sent..
