HV Pack Voltages & Grid Charging
Discussion in 'Gen 2 Prius Technical Discussion' started by Artric, Oct 13, 2010.
  1. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    What is considered "cool" and what type of charger are you using? If possible, please post the make and model number.
    I can locate A1 and A2 but not A3 on the battery ECU. Can you tell me what page is that on?
  2. pEEf
    pEEf Engineer - EV nut
    720
    580
    Berkeley, CA
    I do this all the time on the bench. I can't give you specific temperatures, but you are probably ok as long as you keep them below 100F and there is enough airflow to dissipate 50 watts worth of heat. I use a custom-built charger.
    It's not on any page. The pins are not used in the normal car wiring harness, so you have to add the pins.
  3. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    This is above my level of expertise. I will now stop my inquiries before I make me or my car explode into a big fireball.:flame:
  4. Michael H
    Michael H Junior Member
    30
    Toledo
    --Deleted--
    My bad, posted in the wrong tab I had opened.
