hvac and engine mount bolt questions
Discussion in 'Prius v Technical Discussion' started by presus, Jan 19, 2025.
  1. presus
    presus Junior Member
    33
    ny
    2013 Prius v wagon
    hello all, this prius man. jeez.
    first off, should the ac compressor be running when my defroster are on? it makes the air cold, which is not ideal in the cold weather.
    secondly im missing a nut and bolt for one of my engine mounts. and finding part #s for this car can be a pain in the nice person at times. maybe someone could help, its the passenger side one on top.
    finally im suspecting a blown head gasket? or maybe a cracked egr cooler, im burning coolant, no over heating or boiling over out the overflow.
    i have a p219a i believe it is. what a pain. hope everyone is well
  2. ChapmanF
    19,041
    It also makes the air dry, which is ideal for defogging the windshield.
  3. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    P219a Fuel System Air Fuel Ratio Cylinder Imbalance Monitor
    The ECM uses the air fuel ratio sensor and crank position sensor to monitor the difference in air fuel ratio between the cylinders caused by differences in injection volume between the cylinders, leakage in the intake or exhaust system, etc.
    When the air fuel ratios of the cylinders are lean or rich with respect to each other, the ECM determines that a problem is present and stores a DTC.
    Air Fuel Ratio Sensor Monitoring Method: P219A is stored primarily when a rich side imbalance is detected.
    When the system detects a difference in the air fuel ratio between the cylinders due to fluctuation of the air fuel ratio sensor output over 1 engine cycle (2 crankshaft revolutions), the system determines that there is a problem.
    The reasons for the imbalance between the cylinders can be: misfires, uneven fuel supply, uneven air supply. A dirty EGR system can also do its dirty work. Channels with different degrees of contamination provide uneven air supply to the cylinders. In one, the fuel burns well, in the other it does not burn out. Look at this topic, it clearly shows what the intake channel 1, 2, 3, 4 has turned into.
    Misfire and Air-fuel ratio imbalance | PriusChat
  4. Mendel Leisk
    42,362
    What's the miles?
  5. presus
    33
    ny
    2013 Prius v wagon
    BIG pushing 370k right now. not sure if the motor is original
  6. Mendel Leisk
    42,362
    Wow, that puts it in context. Recently acquired?
  7. presus
    33
    ny
    2013 Prius v wagon
    yea i got it september, with around 349k if i remember correctly. i do uber. it was an old taxi cab so it has rubberized floor instead of carpeting haha. i got it for $1995 :ROFLMAO: needed the abs unit replaced got one for $500 i believe and needed some other little things here and there but pretty solid for most part. it is a total jalopy though wow. im hoping i can squeak out another 30-40k on this engine. the lack of engine mount hardware makes me think this isnt the original engine.
  8. Mendel Leisk
    42,362
    That engine mount needs to come off for either head gasket replacement, or for reseal of the timing chain cover.
