HVAC knob changes multiple degrees/windpseeds/modes with one click
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by xqk13, Jul 5, 2021.
  1. xqk13
    xqk13 New Member
    US
    2016 Prius v wagon
    Just got my 2016 Prius V and the HVAC knob started to act weirdly after a few days. When I turn the knob clockwise one click, it would have the same effect of turning it two or three clicks in all three adjustments. It behaves normally when turned counterclockwise. Have anyone experienced this issue and would this be an expensive fix? Thanks.
  2. MrZap
    MrZap New Member
    28
    British Columbia
    Three Touring
    The way the knob works is there are gear tooth like shapes on the inside of the knob that stroke a three position momentary switch (spring returned to centre). The switch has a little triangle on it as the switch actuator. Maybe not a very good explanation but .......
    This has not happened to me but I'd guess something wrong mechanically with the switch. Like spilled coffee or other contaminant. Or maybe the little triangle is worn? Trouble is, I don't think the knob can be removed from the AC controller. If I'm right, you will need to remove the AC control unit from the car and then it is pretty easy to take it apart or if necessary buy a new one from the wrecker. Getting the AC unit out requires first removing the radio. On a thread about radio upgrades, there is some info posted that might be useful here.
    Tim Jones and xqk13 like this.
  3. xqk13
    xqk13 New Member
    US
    2016 Prius v wagon
    Thanks for the explanation! It is clear enough. Also thanks for the link, I will check it out, hopefully not too much of a hassle.
  4. Tim Jones
    Tim Jones Senior Member
    1,046
    384
    SE Texas
    2013 Prius v wagon
    XLE AWD-e
    Did you ever find out anything about this?
  5. xqk13
    xqk13 New Member
    US
    2016 Prius v wagon
    I bought an used HVAC control module (the assembly below the head unit) and plan to put it on. My current one works ok though, so I’m not in a hurry to put the new one in. Bought it just in case because 15-17 parts are way rarer than 12-14 parts.
  6. Tim Jones
    1,046
    384
    SE Texas
    2013 Prius v wagon
    XLE AWD-e
    Mine still works but I'm pretty easy on the dial.... good to have the other one cause it could go out at any time.
  7. xqk13
    xqk13 New Member
    US
    2016 Prius v wagon
    I wonder what “broke” mine, I’m very easy on the dial so I would think it’s the previous owner.
Loading...
