HVAC Question................. Is AUTO the best setting?
Discussion in 'Gen 4 Prius Main Forum' started by atterbury90, Nov 27, 2019.
  1. bisco
    52,880
    but the fan speed is. if you're adjusting temp to change fan speed...
    i turn the fan on and set the temp, is it all that different from auto?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Auto needs a temperature set. I've only got the one temperature adjustment, but I think some have a L/R split. But once the temperature is set, air outlets and fan speeds are set and adjusted accordingly.
  3. Merkey
    Merkey Active Member
    331
    306
    Birmingham, Michigan
    The auto button seems to have a mind of its own.
    bisco and Mendel Leisk like this.
  4. alanclarkeau
    7,045
    7,593
    There's no FAST / ECO / NORMAL setting here - not mentioned in the handbook either. And looks like you have Dual temperature settings.
    Yours looks like this: upload_2019-11-30_13-39-25.png
    Ours looks like this: upload_2019-11-30_13-40-24.png
    Tyfly and kithmo like this.
  5. Chris Wolfgram
    Chris Wolfgram Active Member
    425
    169
    Sacramento CA
    2019 Prius
    Thank you. I didn't think I was just tripping.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Yes it does (other handed, same side as yours) and dual, maybe it's just a UK thing then ?
    alanclarkeau likes this.
  7. alanclarkeau
    7,045
    7,593
    Yes, I guess you might NEED to get Fast Heat. Here - rarely use heater. But A/C works fine.
    kithmo likes this.
  8. bisco
    52,880
    i wonder if we've answered the o/p adequately (n)
    alanclarkeau, kithmo and jerrymildred like this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Not yet. It's only been three pages. :LOL:
    alanclarkeau, kithmo, Merkey and 2 others like this.
  10. bisco
    52,880
    you nailed it in the first reply, maybe he figured it was sufficient.:)
    alanclarkeau, Merkey and jerrymildred like this.
  11. Chris Wolfgram
    425
    169
    Sacramento CA
    2019 Prius
    Not really. Its confusing as chit. I have decided though, that Auto sucks. WAY too low of fan speeds for me. When I try to use it, it has it on only 1 or 2 clicks. I'd prefer at least half or 3/4's...4 or 5 clicks.
    jerrymildred and bisco like this.
  12. jerrymildred
    11,517
    14,171
    Tampa, FL
    So then the answer to the question -- for you at least -- would be, "No, it's not the best." Which helps to show that different people have different preferences, which is why we have options. ;) If I have it on auto and the fan speed is too low, I'll either bump down the temperature, which keeps it on auto, or bump up the fan speed.
  13. Tideland Prius
    16,683
    It’s a European option (they have dual automatic climate control).
    We just have Eco and normal.
    alanclarkeau and jerrymildred like this.
  14. Mendel Leisk
    42,364
    I usually have it on Auto, but if I'm heading east on a cool (and/or rainy) evening, onto the coastal Barnet Highway, overriding mode to Heat/Defog is mandatory, and I don't think I've ever seen Auto opt for that. And of course this means (on a dark/twisty road): looking down to find the Mode button (in a row of similar buttons), and pushing it multiple times while watching the mode icons scroll, on a small LCD display. You don't want to rush either, cus if you overshoot you'll need to scroll through them all again.
  15. Tideland Prius
    16,683
    Weird. I have seen AUTO go with foot/defrost.
  16. jerrymildred
    11,517
    14,171
    Tampa, FL
    If I'm not mistaken, mine does that when it decides to heat the cabin rather than cool it.
    Merkey likes this.
  17. Mendel Leisk
    42,364
    Maybe I'm just impatient. When the windshield starts fogging up, I'm not waiting to see what it'll do.
  18. Tideland Prius
    16,683
    Yes that’s how I’ve seen it operate as well.
    Haha.
  19. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Whenever I encounter that, adjusting the temp about 2 degrees bumps up the fan speed.
  20. Tideland Prius
    16,683
    It selected it tonight with the rain. It also stayed that way through the entire trip so there was no issue with fogged up windows.
    Mendel Leisk and alanclarkeau like this.
