HWY MPG for the 2010 Prius. PLEASE HELP!
Discussion in 'Gen 3 Prius Main Forum' started by Indyking, May 28, 2009.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    If you can see through that I know you are going to pick Prius over Jetta TDI. If you don't, you owe us a huge detailed explanation!
  2. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    OK, I test drove both again, but this time, requested a long drive, mostly in hwy since that's where I will spend most of the time during my new commute. I decided that the Prius performance in the hwy is acceptable, though I cannot deny that it does not compare with the performance of the Jetta TDI.
    I guess it's obvious from the previous discussions that the advantages of the TDI offer a better fit for my needs and my second test drive came to confirm that. Honestly, the TDI is really the car I wish to drive in my new commute but there are other factors to be considered. To make a long story short, after my extensive homework, I could not sell myself to the reliability of the new Jetta. Lots of TDI owners claim the car is a lot more reliable than most people think. They also claim that anti-VW culture due to mistakes of VW of America in the past still plays a major role on the supposedly false bad reputation. They say the new TDIs are rather well built and reliable, as long as I take the adequate care of it. That means avoiding most VW dealer services, which is something that really bothers me. Not sure if I would trust my car to the recommended gurus either. I called some VW dealers in the state to check what they recommend as far as maintenance schedule and there was a clear disconnect, so I can only conclude that their service has questionable quality at best. I did not do the same with Toyota but I doubt they would be similar. I guess you can see where I'm going here...
    The second factor is fuel economy... I'm convinced that no matter the circumstance is the Prius is more economic, even in the hwy. That may compensate for the difference in price between the 2 because the Jetta would cost significantly less because I was going to get the manual transmission plus the tax credit. It all depends how gasoline vs. diesel will behave for now on, who knows, but right now diesel is 35 cents cheaper here, which is a lot in my opinion.
    So, summarizing, I'm giving the new Prius a try because I decided the Jetta is too risky. Now, it's not set in stone yet because I'm having problems negotiating a price with the Toyota dealers. They all seem to be going considerably above MSRP around here, is that what everyone else is experiencing? The VW dealer is asking right on MSRP, although it used to be bellow some weeks ago because the salesmen said VW was not expecting such high demand for the TDI. It will also depend how much they will give for my trade-in. So, we will see...
  3. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I assume you test drove the Prius with 15" wheels since you were looking for Prius II. Jetta TDI has 16" so it will feel more responsive and "more on the rail". I wonder how the 17" Prius V will compare to the Jetta TDI. I have after-market 17" rims and the handling difference is like a completely different car.
    Is that based on your long test drive? How many MPG did you get?
  4. bwilson4web
    16,549
    Ebay solves the problem very nicely.
    GOOD LUCK!
  5. Indyking
    1,280
    Actually drove the Prius III, does it have 15" wheels?
    Yes, got 47 MPG with with the jetta, about 30 miles, almost only hwy at speed limit, so clearly higher than EPA. Got a bit higher MPG (49) with the Prius, also mostly hwy at speed limit, but I kept the speed less stable with the prius because I wanted to test it's torque in the hwy, so my driving habbits were better with the jetta.
    I'm under the impression that in my weekly trip to Wisconsin (700 miles round trip) I can average maybe about 55 MPG in the Prius driving at steady 70-75 MPH (have to re-educate myself)... what do you think? I guess except in the winter...
  6. bwilson4web
    16,549
    I think you'll be in the 52-49 MPG range. There may some tweaks to bring it up a bit but 55 MPG is a stretch in this range:
    • tires at max sidewall
    • partial radiator block depending on temperature
    • straight gas, if available
    If you slack off to 65 mph, you'll get 55 MPG easily. Given the long distances, look long and hard at 'lane following' and 'automatic cruise control.' These can reduce your driving load and make it a lot easier to hack out the 700 mile legs.
    I used to commute between DC and Huntsville AL, 725 miles, and soon learned 'where to stop' and 'cheaper gas.' My personal preference is to do 500 miles, take a dinner and walk around, and then finish the trip.
    GOOD LUCK!
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    IndyKing, I think it's OK to turn off the bold.
    I doubt much over 50 mpg at 70 - 75 mph.
    This graph is courtesy of Consumer Reports, and looks at 10 year auto reliability by manufacturer:[​IMG]
  8. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Yup, Prius III has 15" wheels. You managed to beat Prius EPA highway 48 MPG.
    Did you use the Power mode?
  9. Indyking
    1,280
    That doesn't surprise me, although like discussed before, I do believe this graph will look a lot different in 10 years... I'm not saying that VW will completely catch up with Toyota and Honda in 10 years but I believe it's narrowing the gap with the latest models. I'm surprised to see Hyundai that far from the lead, I have had very positive experience with the only Hyundai I had (better than my previous civic), and have several friends with similar feelings about Hyundai, which just come to prove how these consumer reports graphs can be misleading to a certain degree.
  10. SageBrush
    11,627
    2,533
    Southwest Colorado
    IndyKing,
    You also said that people's perception of poor VW quality dates from their grandparent's experiences. As this graph makes quite clear, VW reliability is very poor up through the latest data long-term information available. You really should make up your mind whether you want to buy a car based on data available or simple subjective preference.
    "Beliefs" about future reliability trends do not belong in a data driven discussion.
  11. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    Ah, good angle. Never thought of that. There are those who think cramming in the clutch and whipping the shifter to the next gear pretending they are NASCAR drivers on public roads is fun, others think seeing how long they can hold a glide or EV is fun.
    The second are much safer and use a lot less fuel :)
  12. bruceha_2000
    3,057
    302
    Northwest VT
    2018 Prius Prime
    You will find that 'testing' the hwy torque dragged down the MPG. Any stomping on the accelerator is hugely wasteful :) Also, if you are using the 'how does it feel' torque test, there is NO 'lag, downshift, rocket forward' feel to the Prius, just a smooth increase in speed. Many think there is no power because there is no 'jerk'.
    I do slightly better in the Gen II Prii at a steady 65 MPH (warmer weather) than you got in the TDI.
    If you want to get 55 MPG, you will have to slow down. Worse in winter. Snow tires, crud on the roads, cold temps. As suggested, look into grill blocking and some device that will display the coolant temp. I REALLY wish Toyota cared about us cold weather drivers enough to create an automatic (aerodynamic) grill blocking system based on coolant and inverter temp. It would, in fact, improve MPG for ANYONE who drives at temps below 50F. At least in the Gen II, not sure how well the heat recovery system in the Gen III might keep the MPGs up in temps below 50F.
  13. Indyking
    1,280
    See, driving almost 400 miles weekly each way from here to WI at bellow 70 MPH is not an option. I don't want to spend 7-8 h to get there. That's why I was hoping to do at least 50 MPG at 70-75MPH. I know, 80 MPH is out of question. I think the Jetta at 70-75MPH on average will do something close to 45-48MPG (at least that's what users are recording), so I can't see why the Prius couldn't do around 50MPG. Another thing I have not researched yet... and maybe somebody here can help me out with a honest answer. Which one of the 2 (09 Jetta TDI vs. new Prius) is likely to deliver better MPG in cold temperatures at same average speed? I haven't thought about that but maybe I should because I will be driving on cold to extreme cold conditions for a significant part of the year (WI residents know what I'm talking about). Can anybody help me PLEASE?
  14. Indyking
    1,280
    I mean HYW miles at steady 70-75 MPG... no city driving because the Prius is a cleaner winner in stop and go...
  15. bwilson4web
    16,549
    I can only report that my Prius highway mileage falls off in the cold at the same rate that the air density increases ... assuming you use a radiator block:
  16. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    If you live close to the highway, you will have minimal MPG hit. 2010 Prius warms up faster and it provides cabin warmth by capturing exhaust heat. A long stop and go traffic before reaching the highway will lower your MPG. However the new exhaust heat recovery system is suppose to improve it.
    Still, there are a few things that will contribute to lowering your MPG. Winter gas formula has less energy. Rolling resistance will be higher in the snow. Longer warm up time (compare to Spring/Summer). Expect about 3-4 MPG hit. That's coming from 3 winters experience in NY with 2006 model. I block my grill in the winter to shorten the warm up time.
    I have no clue if Diesel's winter formula has less energy or not but I heard it takes longer to warm it up. It does not capture exhaust heat either as it is the latest generation of hybrid exclusive premium feature.
    Note: I want to add a note that 3 to 4 MPG hit is due to my weekend and other misc short trips (lunch break, etc..). If you purely drive on the highway (95% as you stated), you should see maybe 1-2 MPG hit.
  17. ljbad4life
    ljbad4life New Member
    365
    24
    At this point, I don't think you should be concerned with which car gets 50mpg at hwy speed, but which car will actually start in the winter. I just took a quick look at that TDI forum.
  18. Indyking
    1,280
    That's very helpful... THANKS!
  19. Indyking
    1,280
    What do you mean?
  20. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Well, that explains everything! See, I was confused when my MIL's dealer-maintained MB E300 turbodiesel blew the engine...as in catastrophic internal damage...at 160k. I was also confused by the fact that so many HEVs have run that long without any problems with the battery, engine, or any other drivetrain component whatsoever. But, hey, you seem to know everything about your product. Those 30k transmission service intervals on the DSG must be a "feature" that I didn't know about.
