Hwy vs Stop and go
Discussion in 'Prime Fuel Economy & EV Range' started by Big River, Jul 31, 2022.
  1. Big River
    Big River Junior Member
    Baton Rouge
    2022 Prius Prime
    I get my prime in two weeks. I have two main options to get to work - 16 miles away.
    One option is the interstate. The other is straight thru town with stop and go recharging.
    I will not be connecting to charging while at work.
    I want to make the whole trip on EV. Thanks for your suggestions.
    Big River
    52,691
    congrats and welcome!
    you'll do far better on back roads because lower speed requires less energy. you won't get a lot back from regeneration, but you will get some.
    use of hvac in different seasons/temps will hhurt a little either way, and rain causes friction, decreasing range.
    all the best!(y)
    jerrymildred and Salamander_King like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Welcome and congrats.
    You will not make the round trip on only EV on the highway. You can make it on surface streets depending on speeds, how much you use your brakes, and how often the traffic lights or the car in front of you force you to brake hard. And the weather is a big factor.
    MTN likes this.
  4. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    Welcome. Test both options and let us know.
    MBurch likes this.
  5. BiomedO1
    BiomedO1 Senior Member
    4,440
    2,337
    Left Coast
    If you can time the lights properly, avoid stopping and restarting, keeping it around 45 mph - you should be able to make the round trip.
    Wet roads and rain will have a huge effect on MPG; it actually goes down with these cars.
  6. Big River
    Baton Rouge
    2022 Prius Prime
    An update, love my prime. Replaced a chevy tahoe with 300k miles. EV miles is great without a/c but since I live in Louisiana it's a must. Hope it can duplicate the chevy in longevity.
    bisco and jerrymildred like this.
  7. steve0826
    steve0826 Junior Member
    30
    Bellevue, WA
    When you drop from 65 to 55 MPH, does your Prius Prime switch to EV mode?
  8. jerrymildred
    11,517
    14,164
    Tampa, FL
    Normally, yes although it's not really "EV mode;" that's the mode you select with a push button. You're still in HV mode, but the ICE is off and it will say EV above the bar on the HSI display but it won't say "EV mode" by the speedometer. And the battery state of charge also has a say in it. On flat ground without a headwind, 60 mph seems to be about where it needs more power than the car wants to provide in EV when running in HV mode.
    Tideland Prius likes this.
