Hybird Battery HELL
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MrsIngraham, Jul 8, 2017.
  1. MrsIngraham
    MrsIngraham New Member
    Atlanta, GA
    I've got a 2004 Prius with approx. 146k miles. About 3 weeks ago the Red Triangle of Death appeared after church, along with all of the other associated warning lights. After taking it to our trusted mechanic, and having the codes read, they determined that the hybrid battery was officially dead. The car has been perfect since it was bought new, so we elected to replace the hybrid battery through a local Prius battery specialist. We paid $1850 for a new battery with a 2-year warranty.
    After driving it from Atlanta down to the Jacksonville area, we had no problems. Today, as we were leaving to go home, the Red Triangle of Death appeared again, with the other warning lights. We also noticed the battery vent in the back seat was blowing very hard. We tried to drive it to a safe location, but the car started accelerating strangely, so we pulled over.
    Has anyone had this happen before? I'm at my wits, and wallets, end with this car :(
  2. JC91006
    16,937
    8,647
    This is a common story from prius experts rebuilding batteries. They're probably not that expert at it.
    What you got is a poorly rebuilt battery, not new. Now that they have your money, you can prepare for multiple breakdowns and hope they honor their warranty
    Deogratias likes this.
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Yes, I'm on my third battery repair (that's what you bought; a repaired battery, not new). If you want problem free, get a new battery from Toyota and be good for another 10 or so years. It's gonna' cost ya' tho'.
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    If you read through the HV battery replacement threads on this site.......you will see that what he said is absolutely true.
    It is also good to check/replace the 12 V battery as it can cause false failure reports too.
    Sorry for your trouble.
    You probably will be seeing that "local Prius battery specialist" several times over the next two years.
    Did you by any chance do a network search for that company to see if you could find any reports on them ??
  5. MrsIngraham
    Atlanta, GA
    They seem to be a new company, but the owner seemed very knowledgable and willing to help. Since there is a warranty, I'm towing it back to him. I spoke with him today about the situation and he said it was not common. I will double-check the 12v battery.
    Are there no refurbished battery success stories? I can't be the only one without a spare $3500 for a new battery lying around.
    Dxta and bisco like this.
  6. bisco
    52,879
    unfortunately, it's hit or miss. some folks have had decent luck with companies like dorman, while others have not.
    and there are some real scams out there as well. all the best!(y)
    #6 bisco, Jul 8, 2017
  7. fotomoto
    5,639
    3,815
    So. Texas
    Sure. Early on a rebuilt batt was the way to go as the pool of good modules was plentiful and cheap. New individual modules aren't available so this cottage industry has been dealing with used modules that are getting older every day.
    Raytheeagle, Deogratias and m.wynn like this.
  8. Sam Spade
    2,036
    1,024
    2017 Prius c
    Those two things don't seem to go together.
    GrGramps likes this.
  9. Sam Spade
    2,036
    1,024
    2017 Prius c
    REALLY ??
    That seems like a critical piece of information.
    Of course, a "rebuilder" could buy a brand new battery assembly from Toyota and "part it out", thus giving him new modules to work with.
  10. fotomoto
    5,639
    3,815
    So. Texas
    Yup. Rebuilt or refurbished implies repaired with new modules but nope, they are used. IIRC, one PC member supposedly found some chinese knock-off's on alibaba but AFAIK no one has verified or tried them.
    Just about anything is possible but I don't think that would be cost effective on a large scale. Plus, I don't think the new modules would match very well, performance wise, to nearly 14 year old ones.
    m.wynn likes this.
  11. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    The industry has not decided on clear language policies regarding: Rebuilt, Refurbished, Overhauled, Reconditioned, and other language that is suggestive of similar ideas. Therefore, there are success and horror stories surrounding each descriptive for a given part - those responsible for the component to not all subscribe to the same standards, therefore YMMV!
    No, you are not the only one without $3500 laying in wait for a HV pack to fail. Most, if not all owners of used Hybrids are mentally in Las Vegas with their HV packs, rolling the dice while hoping not to have to pay the piper.
    In my(opic) view, unless you can get a new HV pack from Toyota, it's still some wild gamble. A guaranty or warranty is only useful if you don't need it, after all the lack of transportation while repairs are effected is also costly.
    uart likes this.
  12. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    As fotomoto has already said, you cannot just add a new module or two to a failed pack. It will not work as the old modules will not play nicely with the new ones. The only way to do it is to replace all the modules with the new modules, which is what Toyota are effectively doing with a new pack. It would not be cost effective for a "rebuilder" to do such a module swap, for obvious reasons.
  13. Sam Spade
    2,036
    1,024
    2017 Prius c
    You are right, of course, but I think you underestimate the levels of deception that some people will go to.
    Doing that would allow them to say "New cells are used in the rebuilding process".......when in truth only a few are used AND that really isn't a good thing......but it SOUNDS good.
    dolj likes this.
  14. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    There are quite a few unscrupulous folks out there doing all sorts of shady things when it comes to hybrid batteries.
    For the most part, if it sounds too good to be true, beware.
  15. MrsIngraham
    Atlanta, GA
    Update:
    Took it to Atlanta Prius (where we got the refurb battery) and he got the codes P3011 and P1121. Said that the coolant flow control valve was the culprit. Said the heat of Florida, combined with the long trip, caused the car to go into Safe Mode. Said that the battery was showing a little bit low, so he went ahead and put in a new Hybrid battery since I'm still under warranty.
    Is this making sense to those of you who have more Prius and mechanical experience than I?
  16. 05PreeUs
    1,097
    565
    MSP
    We drove our '05 for MONTHS with an intermittent (mostly active) P1121, it never caused a performance issue and no, heat did not cause the failure. I recently documented on PC the internals (also have some videos here:
    As for P3011m that is directly related to the HV battery you just had replaced:
    P3011 TOYOTA Description
    If there is an abnormal internal resistance or electromotive voltage in the hybrid battery blocks, the hybrid battery Electronic Control Unit (ECU) determines that a malfunction has occurred. When the malfunction detection condition is satisfied, the battery ECU illuminates the MIL and sets a Diagnostic Trouble Code (DTC).
    telmo744 likes this.
  17. JC91006
    16,937
    8,647
    If you had a battery for less than 3 weeks and he's saying "it's showing a bit low". I hate to imagine what would happen after 1 month. Hopefully this battery he put in will be better......
  18. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    What industry is that? . CraigsList come on by and get a rebuilt hybrid battery full of used batteries and corroded buss bars with a tail light warranty? WoHoo!
    Whack A Mole Industries LLC.
  19. edthefox5
    10,096
    4,840
    Clearwater, Florida
    P3011 is a bad battery module. Classic whack a mole rebuilder baloney. Now you know.
    Get your money back and go get a new battery from Toyota and motor on down the road for another 200,000 miles or trade it in.
    m.wynn, Deogratias and Montgomery like this.
  20. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    For an approximate $12.50 per week, in 7 years, one would have $3500. I plan on keeping mine for as long as possible. I have been putting away this amount since day one. I don't plan on buying any other type batteries except a "new" one from toyota.
    m.wynn, uart, dolj and 3 others like this.
