Hybrid Assistant data interpretation needed
Discussion in 'Gen 3 Prius Technical Discussion' started by Will Stewart, Sep 10, 2020.
  1. Will Stewart
    Will Stewart Junior Member
    45
    Northern Virginia
    2014 Prius Plug-in
    I am assisting my daughter with her purchase of a used 2014 Gen 3 at 106k miles. The general output from Dr. Prius looks ok, and the Full Battery Check (not the mode where one stomps on the brake and accelerator simultaneously for over a minute) returned all categories checking out.
    I then ran the HV Check in Hybrid Assistant, with screenshot and report attached (oops, cannot upload an html file). I think based on what I've read that it appears this battery is in fairly good shape for its age and mileage, though I'd like a confirmation that it is indeed. The difference at lowest discharge between the max V cell pair and the min V cell pair is 0.17V, which would put it in roughly the 90% acceptable range. However, the maximum difference within the entire data set is 0.27v, which would put it closer to 85% acceptable, if I am understanding this correctly.
    Could one or more persons weigh in with their knowledge?
    #1 Will Stewart, Sep 10, 2020
    52,876
    i can't help with the battery, just a reminder about the egr circuit and head gasket.
    all the best!(y)
    Will Stewart likes this.
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Looks healthy. I run the same app and the voltage differences are within .3v from highest to lowest cells on average. My last tank was 67.0 MPG driven 530 miles w/100 miles a day interval, take this info as-is.
    Will Stewart and bisco like this.
