hybrid assistant wont connect to bluetooth
Discussion in 'Prius OBDII Third-Party Apps' started by ozmatt, Feb 5, 2021.
  1. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    Hello, having trouble getting HA to connect or pair to bluetooth obd2, tried Camry AVV40 and Prius XW30, tried 4 different mobile devices and two different obd2 adaptors including popular Viecar V4.0 which is known to work well for most others
    Dr Prius and a couple other hybrid apps connect fine, its just HA wont work and I want it to command the fan ramp up on hot days!
    BTW i am in Australia not sure if that makes any difference
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Hybrid Assistant is very particular about what OBDII adapter you use because it needs very high speed. Here's the page where they list what they know works and doesn't work. I already had three adapters including Carista that didn't work or didn't work completely. I broke down and sprang for the OBDLink LX and it works flawlessly. Not cheap but no more hassles.
    Hybrid Assistant: OBD
    #2 jerrymildred, Feb 5, 2021
    SFO, ozmatt and Salamander_King like this.
  3. ozmatt
    637
    263
    Australia
    Hi Jerrymildred, thanks very much for that :) I actually bought the Carista Viecar v4.0 because it was recommended on the list, and high speed
    Go back to the list today and it says results may vary for the Carista adaptor and be aware of clones! i have to think we have clones
    Question is now, what is the cheapest known working adaptor :)
    Cheers thanks again for the advice much appreciated..
    Matt
  4. jerrymildred
    11,517
    14,167
    Tampa, FL
    Keep in mind that what works on your 2010 might not work on the next car. The Prime, for example uses some tech that the Carista can't access. It's OK for code reading/resetting and customizing on my Prime, but can't keep up with HA's demands. HA is pulling a lot of data. The OBDLinx LX I got is the cheapest I found that for sure works. I might have spent a few hundred dollars trying out cheaper ones, but I just decided I already own enough cheap ones. Too many, in fact.
    ozmatt likes this.
  5. ozmatt
    637
    263
    Australia
    Thanks again Jerrymildred
    I just read again the Carista is actually in the list of known working adaptors for most cars pre 2015, so we must have got clones
    and although it says Viecar on the adaptor and package, it only said Carista on the ebay listing, not on the adaptor! thanks again china
  6. ozmatt
    637
    263
    Australia
  7. AzusaPrius
    AzusaPrius Senior Member
    2,257
    945
    Yup fake I have a legit Carista and it says Carista on it.
    ozmatt likes this.
  8. ozmatt
    637
    263
    Australia
    damn china and their fake rubbish honestly
  9. AzusaPrius
    2,257
    945
    @ozmatt
    You can let ebay know and you will get your money back.
    Report the seller and the item as fake and point out the listing says Carista not icar or whatever it is.
    jerrymildred likes this.
  10. ozmatt
    637
    263
    Australia
    Yeah i bought it over 6 months ago, guess i could still give it a try but doubt it will work
    will just resell as a clone for what i paid .. and buy another
