hybrid assistant
Discussion in 'Gen 2 Prius Technical Discussion' started by kinglew, May 12, 2019.
  1. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Look for info what obd works with hybrid assistant.the elm i have works with torque not hybrid assitant.thanks in advance for any help
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    This is the one I use with Hybrid Assistant:
  3. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    i don't see anything in your post except this is the one you use no link pic etc
  4. john1701a
    12,840
    5,312
    58
    It's the app you are viewing posts with causing an issue. When that happens, just open the message in a browser.
    Here's what to search for on Amazon: "ScanTool OBDLink LX Bluetooth" It's the green device for $49.95
    MickyMatter likes this.
  5. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
  6. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    thanks look for less expensive obd adapter . i know there are some that work with it .thanks for your help
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Hybrid Assistant: OBD
    It would make sense to use the OBD device that the app designer recommends for it................
    there's a whole selection on their website with various ratings..
    MickyMatter and SFO like this.
  8. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
  9. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    I've the same problem viewing links in Tapatalk. But there's an option behind the three dots to view the thread in the browser.
    I used a cheap (<10 €/$) no-name for some years with Torque Pro.
    But it didn't function with Hybrid Assistant. But this green one is really good, works with Torque Pro and Hybrid Assistant too and is much more stable. (But I had to spend, converted in $, more than 100.)
    SM-G950F ?
  10. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Thanks .want try hybrid assistint but dont want to spend a lot on dongle. Have one that works with torque.and techstream.look for cheap dongle that work with hybrid assistant.
    #10 kinglew, May 12, 2019
  11. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Looking for info on dongle that works with hybrid assistant.resonable price if any can help thanks in advance
