Hybrid & Aux Battery Problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Blaq, Jun 9, 2015.
  1. Blaq
    Blaq New Member
    Boston
    Hello!
    I have a 2008 Prius w/ 128k+ miles & recently had my car throw a "Hybrid System Malfunction" light and shut off while on the highway.
    History:
    In January, I was having problems starting up the car, took it a dealership and they said the aux battery was low and quoted me at $400 to replace w/ an OEM.
    I did some research and it was suggested to me to get the optimum battery from elearnaid.
    Toyota Prius 12 Volt Auxiliary Battery with install kit for 2004 + including Plug in
    Ran me $200 and my private mechanic put it in for $50. He told me when he went to replace the battery, he checked the old one and it was fine. I told him to put in the optimum anyway since the internet told me it was better and I'd already paid for it.
    Problem solved.
    Now:
    I was driving my car, engine felt off (didn't feel like I had much power over 55mph), MPG is down to like 20 (from 45-50). "Hybrid System Malfunction" light comes on, car smells funny. And suddenly the engine just turns off while on the freeway.
    According to mechanic/dealership codes being thrown are about low voltage in hybrid battery and aux and low power to transmission and possibly other things.
    Mechanic tells me to take it to a dealership b/c of the hybrid system lights.
    Dealership tells me both the aux battery and the hybrid battery are very low (aux is at 9v after 4 months).
    First step, they want to replace the aux and see if that fixes everything.
    So my question:
    Should I try to get another Optimum battery since this one seems to be defective/not holding a charge? (I assume eLearnAid has some sort of warranty.)
    Is it possible the Optimum Battery is not the problem and the Hybrid battery may have an issue that's drained it?
    Should I just stick with the dealership through this process since it's getting complicated?
    Do aux battery problems really have the ability to mess with my hybrid battery? I thought the aux battery just helped turn the car on (which I've had no problems with).
    52,886
    could be inverter or inverter coolant pump. definitely start with elearnaid. maybe you can charge your old one in the meantime and see what happens. once powered up, see if there is turbulence in the inverter tank.
    Blaq likes this.
  3. JC91006
    16,938
    8,647
    if the battery is at 9v, it could be your car's dc/dc converter (the prius version of an alternator) not functioning. If that was functioning, if your car was running, even if the battery was disconnected, it would still not shut off.
    Blaq likes this.
  4. Blaq
    Blaq New Member
    Boston
    So it appears I'm just a moron.
    I drive my car once a week for about 2-3 hours. Apparently this is not enough to maintain a charge in the aux battery and was most likely the cause of the first problem and the cause of this problem.
    Does that sound reasonable?
    Looks like I need to replace the battery and sell the car.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    While 2-3 hours once a week is certainly NOT a lot of drive time, I would still think with a healthy aux battery you wouldn't have a problem.
    However, I suppose if you are only driving a Prius 2-3 hours a week, once a week, selling the Prius and getting something less battery dependent might be a good move.
    It's up to you.
    If the dealership is saying BOTH the aux battery and HV battery are low, it's quite possible you have a bigger problem than just the AUX battery. If the HV battery is on the way out? That's a much bigger expense.
    Blaq likes this.
  6. Blaq
    Blaq New Member
    Boston
    When I called eLearnAid, he told me driving that little qualified as abuse/neglect and thus it wasn't a warranty issue. Is it possible the battery was a dud?
    I misunderstood the dealership originally (there were 5-6 codes being thrown), nothing to do with the hybrid system, they said that battery was fine.
    Still haven't explained why I saw that original light "Hybrid System Malfunction"
  7. JC91006
    16,938
    8,647
    elearnaid is lying to you, there is no requirement in driving the car a specified amount of time to keep the warranty.
    If your battery was a Yellow Optima, then you could have gotten a dud.......as I had once before getting a good warranty replacement.
    Blaq likes this.
  8. Blaq
    Blaq New Member
    Boston
    It was a Yellow Optima Optima DS46B24R Optima battery direct fit replacement for Prius 2004 + , Prius V & Plug-in Prius with Instructions
    How do I pursue getting the warranty replacement?
    Do I just press the issue with eLearnAid or contact the manufacturer directly?
    I don't see eLearnAid's motivation to lie to me, presumably the manufacturer is responsible for warranty issues.
    And given I had no problems for several months, is it really likely to be a dud?
  9. JC91006
    16,938
    8,647
    It's more of a concern that you said the car stopped while it was in READY mode. That to me doesn't sound like just a battery issue, it may be in addition to the battery.
    Nobody will know how often you drive you car, it's whatever you wish to provide...or not provide. If the battery tests bad within the 2 years warranty, they need to give you a new one. You can take it up with optima if you like, but they will probably direct you back to the retailer you purchased from, which is elearnaid.
    Blaq likes this.
  10. Blaq
    Blaq New Member
    Boston
    That is what I was concerned about. As I understand it the Aux battery just starts the car, it doesn't explain to me why the engine was struggling above 50 or why the engine just cut out on the free way.
    As for eLearnAid, it's a tiny company (every time I call it's the same guy), my story is known. If it does qualify as neglect/abuse, I don't think he's gonna help me out.
    But it sounds like I should maybe just have the dealership replace the battery with an OEM one in case there is a deeper problem that needs to be tackled.
  11. JC91006
    16,938
    8,647
    You should try charging the optima battery, sooner rather than later.
    Those batteries hold up quite well after a deep discharge but........if it's still a dud, you can get another one. I would call optima first, I'm not aware of an abuse clause of not driving enough.
    Blaq likes this.
  12. Blaq
    Blaq New Member
    Boston
    Thanks for the recommendation, I greatly appreciate it.
  13. bisco
    52,886
    ask him to show you where it says that 2-3 hours a week is abuse/neglect in the written warranty. if your battery is bad, and they refuse to replace it:
    THIS IS A HUGE BLACK MARK AGAINST E LEARN AID AND A WARNING TO FUTURE BUYERS.
    i would contact optima directly.
    Blaq likes this.
  14. Blaq
    Blaq New Member
    Boston
    I appreciate the sentiment and will look into it.
    So are you of the opinion that driving a prius 2-3 hours a week is enough to keep the battery charged? Because I've talked to a couple different people and they all seem to think that this is what caused the dead battery, and that it really is my fault.
    And again, if it was a bad battery, would it still last 4 months before having a problem?
  15. bisco
    52,886
    with a good battery, it's plenty. the question arises when a battery of poor health dies for this reason. that's why many switched to the optima, just so this wouldn't happen. it is supposed to have enough amperage withstand serious draining. the oem being low c/a's, when it draws down a bit, there isn't much left.
    Blaq likes this.
  16. Blaq
    Blaq New Member
    Boston
    For future knowledge:
    What is the downward limit on driving enough to keep the battery healthy?
    I didn't know this was something to keep an eye out on.
    Would driving it for two hours once every 2 weeks be okay? 3 weeks? Once a month? [Renting a car at this point seems cheaper of course.]
    My buddy says he's able to start his car after a month or two of not driving without an issue, but acknowledges its an old jeep without any fancy gadgets.
  17. JC91006
    16,938
    8,647
    to solve this problem, all you need is a trickle charger. You can get them anywhere and it'll keep your battery charged up when not in use.
  18. bisco
    52,886
    get a ctek from amazon for 60 bucks.
  19. bisco
    52,886
    i leave my car for 5 weeks every winter, no problem. 3 year old original battery.
  20. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
