Hybrid battery balancing
Discussion in 'Gen 2 Prius Technical Discussion' started by giperbolic, Mar 11, 2014.
  1. giperbolic
    giperbolic Junior Member
    fl
    I'm in the process of balancing modules and wanted to see if anyone has any experience of using higher discharge current. All the related posts I found so far suggest .7 amps (1amp limit of the charger). Has anyone tried using chargers capable of discharging at 5 amps or more? Is there an advantage to a low current discharge?
    Thanks.
    Mike.
  2. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    I believe the issue is that it´s more accurate to measure the capacity with lower currents.
  3. Robert Burns
    Robert Burns New Member
    Tyler, TX, USA
    I'm looking for a step-by-step page for balancing a Prius batttery before attempting to replace a weak cell or cells? Anyone?
