Hybrid Battery Block Numbering ??? Left to Right
Discussion in 'Gen 3 Prius Technical Discussion' started by HV Battery, Sep 10, 2018.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,258
    952
    Gen 3 the modules start from the side of the fan, so if you have the battery still in the car and you are looking at it from the trunk the it is the right side. If you are sitting inside and looking towards the trunk it is the left but always remember the blocks start where the fan is.
    jerrydelrey likes this.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    For all batteries regardless of year or model...
    Find the negative lead.
    Start counting modules from there.
  3. jerrydelrey
    jerrydelrey Member
    111
    22
    Honolulu Hawaii
    Okay Gen3 while pack is mounted in the car facing forward, #1 cell/block/module is on the far right (fan side). Right?
  4. PriusCamper
    PriusCamper Senior Member
    13,475
    5,441
    Pacific Northwest, USA
    Left side... module #1 is always the first place the negative cable attaches to the pack.
  5. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    Maybe a bit late reply but I wanted confirm the above as a future reference.
    That's exactly how 3rd generation modules are numbered.
    Per what the others say, Gen2 is the opposite way.
  6. chronon
    chronon Active Member
    601
    106
    here and there aint be in frozen wasteland no mo..
    Most excellent and concise advise on HV battery verification!
    working on a 2012 battery --Camry .. stupid dealers wouldnt tell me but when i finally called one from out of town i had missed the ending deadline on warranty by only 2 or 3 months this year (last year??) !!! 8 yrs or 100k miles .. which in this case, it has only 95k miles so .. I thought it was 10 years ...
  7. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Is this the same for the Prius C? module #1 is the closest to the battery cooling fan?
  8. ciro ochoa
    ciro ochoa Junior Member
    27
    Three Touring
    is this driver side or passanger side is number 1 ?
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    As installed in the car, the Gen 2 hv battery has block 1 on the passenger side.
    On Toyota HV batteries, Module 1 is always the module that has a heavy orange cable connected to the (-) negative module terminal.
  10. ciro ochoa
    27
    Three Touring
    it doesnt start at the end ? pack one starts on passenger side end,
  11. ciro ochoa
    27
    Three Touring
    gen 2 number 1 is behind passanger side , 14 behind driver side? right )
  12. ChapmanF
    19,060
    Out of the whole pack of modules, the extreme one on each end will have a thick orange cable connected to it.
    The modules also have symbols and molded into the plastic on top.
    On one end of the pack, the orange cable will be attached at the end of the module.
    At the other end, the orange cable will be attached at the end of the module.
    The one that has the cable attached to is module 1.
    This holds across different Prius models and generations, even though it is not always the left or always the right.
    Mendel Leisk and ciro ochoa like this.
  13. GreenApp
    GreenApp Junior Member
    43
    A big reason why boats use fore/aft/port/starboard. It never changes.
  14. ChapmanF
    19,060
    How embarrassing—I thought I had already posted corrections everywhere I had made that mistake, but it looks like I missed this thread.
    The "across different Prius models and generations" part isn't an airtight rule: the gen 1 is an exception. More here, including info on using the wiring diagram and color coding to double-check any 'rule'.
    ericbecky likes this.
  15. Kasra Oskuie
    Kasra Oskuie New Member
    Folsom, CA
    So, Gen 3 from end to the components where the wires go to? Left to right looking at it from the back of the vehicle. Right?
  16. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    The block closest to the fan is the #1 block.
    I think someone posted a Toyota page about that quite a while back.
    #36 ASRDogman, Nov 13, 2024
  17. ChapmanF
    19,060
    There is no fast in a Prius.
  18. zfk110
    zfk110 Junior Member
    97
    Atlanta, Georgia
    Can you please provide the block identification details for the 2011 Prius Gen 3 hybrid battery? I need to replace Block 6 and Block 8, but I want to confirm their exact positions. Specifically, could you clarify the following: sax.jpg
  19. AzusaPrius
    2,258
    952
    Yes that is correct.
