Hybrid battery cell or 12v battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by OldlinePrius, Aug 1, 2021.
  1. OldlinePrius
    OldlinePrius New Member
    Maryland
    About 2 days ago after when I left for work I noticed that the clock was back to 1:00 and my radio station presets were reset. Thinking nothing of it I set the clock fixed the stations and went on about my day. when I got off and made the long drive back home I noticed that it had done it again. The next day I went to run some errands and it started fine but when I got to the store I shut the car off and walked away hitting my key fob to lock the car nothing happen. I got back in and notice the lights were on on the dash, I though maybe I forgot to turn it off (that has happen before). I put my foot on the break and turned it off. This morning my mother needs to use the car to go to church it started fine and she went about her day. She just called from the church a few mins ago saying the doors wouldnt lock and the car will not turn AT ALL.
    is this the 12v or the cells under the hood (sorry I dont know what they are called)
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Yes, that.
    But it might also be a bad connection on one of the main 12 V cables......at either end.
  3. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    How old is the 12v battery?
    SFO likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Welcome. It sounds like it might be a bad ground connection where the 12V connects to the body under the floor in the hatch area on the right side of the car. Also, the connections at the battery terminals can come loose. Or, the 12V battery might just be very low. You should check the voltage both at the battery terminals and also at the jump point under the hood to make sure they are close to the same. Both should be over 12V. If the battery tests good but the jump point is low, then it's a loose connection. My money's on the loose connection. If the battery was so low you lost your radio presets, I don't think you'd be able to start the car.
    By cells under the hood, do you mean the traction battery? That's not under the hood. That's in the rear under the deck. When the car is off, it is completely disconnected by a relay. Pressing the start button with your foot on the brake closes the relay and at that point, the traction battery more or less takes over.
    As for putting your foot on the brake to stop the car, I can't figure out why people do that. As with almost all cars, you need your foot on the brake to start it, not to shut it off.
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    It might be because if you do not put your foot on the brake to stop, you likely will run into the car ahead.
    :ROFLMAO:
    Another likes this.
