Hybrid battery contact cleaning
Discussion in 'Gen 3 Prius Technical Discussion' started by gruzinchik, Mar 15, 2019.
  1. gruzinchik
    gruzinchik Junior Member
    Georgia
    Hello .
    I have the idea to lubricate after cleaning contacts of the HV battery by 3M copper anti-seize brake lub. have somebody practice on it ,it has description
    • High-viscosity lubricant promotes free movement in metal-to-metal applications
    • Blend of tiny copper and graphite metal particles in semi-synthetic oil holds up under extreme pressure and temperature conditions
    • Can withstand intermittent temperatures up to 2000° F
    • Ideal as an anti-seize lubricant for the metal-to-metal contact points of brake systems (not for use on friction material)
    thank you
  2. PriusTime
    PriusTime Junior Member
    55
    23
    No no no do not use this. No lube on the contacts and no way would you ever want to use conductive anti-seize. Clean the contacts and leave them dry before assembly.
  3. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
