Hybrid battery cooling mod
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Jun 19, 2020.
  1. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    The microfans aren’t in a sealed enclosure either so he ll need 2 hammers to get out of level 1 wack o mole.
    PrimeFactorE likes this.
  2. AzusaPrius
    AzusaPrius Senior Member
    2,257
    942
    I will gladly take more tests runs with it off and on. A/C is set to two lines each time. The drives I took for each previous run was a good distance about an hours worth of driving.
    Both days the temps were 95F and since the car is black I would say that outside temps will have an effect on inside temps, that is why I tinted the windows. I live in the high desert so there is literally 345 days of hot sunny days here.
    davecook89t likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Google.....natural circulation...natural convection, etc....
    For example...hot air coming up off a paved road...does it leave an unfilled vacuum on the road surface? Would warm air naturally rising above the modules and flowing out the exit duct leave an unfilled vacuum between the modules? Is it a hurricane? Nope, but it exists.
    It's your car, do as you wish with it. If you post everything you do, take it in stride that not everyone is going to feel the same way about it. Some will lick your balls and tell you how great it is...others won't. Perhaps individuals with life experience/education that varies from yours may not have the same viewpoint as you. It's kinda that ying-yang thing that comes with posting your life on the internet...
    PriusCamper and ASRDogman like this.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Yep, and SOC is beyond 65%. Combination for some unwanted bulging.
  5. AzusaPrius
    2,257
    942
    I understand completely and see when people on here assume things.
    #25 AzusaPrius, Jun 23, 2020
    1prius likes this.
  6. Mykhailo
    Mykhailo New Member
    Poland
    The fan controller is a microcomputer-based intelligent cooling device that automatically adjusts the fan speed to optimally cool the high-voltage battery. Using a fan controller will increase the life of the hybrid high voltage battery by 2-3 times.
    Owners of Toyota vehicles with hybrid engines face problems with overheating of the high-voltage battery due to insufficient cooling. Since the launch of the PRIUS 30, Toyota has steadfastly ignored the importance of proper cooling of the HV battery in hybrid vehicles. After 5 years, the battery loses capacity by 40-50% and begins to overheat due to charging with huge currents, although its capacity has been reduced by half.
    The maximum wear of the components located in the center of the high-voltage battery assembly is strong evidence of systematic overheating. Nickel-Metal Hydride (NiMH) batteries have higher energy ratings but operate within a narrower temperature range and are at risk of overheating.
    When the temperature reaches 45°C, the car’s computer blocks the use of the battery. Although this may go unnoticed by the general driver, this results in the recovery being disabled and the EV (Electric Vehicle) function not being used, as well as increased fuel consumption. If you’re not experiencing battery overheating issue, chances are it’s a bug you just don’t notice. In this regard, it becomes necessary to provide additional cooling of the high-voltage battery.
    The car’s computer controls the battery cooling fan according to certain temperature values:
    Speed 1: 30% fan power at 36°C;
    Speed 2: 31% fan power at 38°C;
    Speed 3: 32% fan power at 40°C;
    Speed 4: 33% fan power at 45°C (this temperature disables battery usage)
    Speed 5: 35% fan power at 50°C;
    Speed 6: 100% fan power at 60°C, a “High voltage battery overtemperature” error occurs, causing the hybrid system to go into emergency mode. There is a risk of battery explosion and fire. In the event of a fire, the flame is small, but it is difficult to extinguish it, especially in the presence of a charge. There is also an unpleasant odor.
    The fan automatically turns off when the temperature reaches 34°C.
    That is, 1 – 5 speeds practically do not differ.
    I wonder why the developers of the program provided such a strategy for changing power at different speeds, since changing power by only 1% between speeds seems pointless.
    Fan noise is annoying.
    Perhaps there were other plans initially, but in the end they decided to sacrifice battery longevity and changed the power values \u200b\u200bat different speeds. The high-voltage battery cooling fan is not prone to breakage, but only becomes clogged with dust, requiring regular cleaning.
    #26 Mykhailo, Jul 13, 2023
  7. Mykhailo
    Mykhailo New Member
    Poland
    So, the conclusion: it is necessary to maintain the temperature no higher than 40 ° C. To do this, it is proposed to increase the fan power at the 3rd speed. It is possible to solve the problem with the help of an electronic unit based on a microcontroller and capable of significantly increasing battery life. Additional cooling for the hybrid high voltage battery is provided by the fan controller.
    Installing the fan controller for additional battery cooling is very simple: it connects to the fan with two connectors in one minute.
    However, if the “High Voltage Battery Overheat” error appears too frequently, the battery may need to be repaired. However, battery repair is about replacing very bad cells with not so bad cells. From such a repair, the battery will not become new and will still overheat. It is not possible to buy a new high-voltage battery as a spare part. She’s just not for sale. Subject to mandatory disposal.
    Fan controller is required.
    #27 Mykhailo, Jul 13, 2023
  8. Mykhailo
    Mykhailo New Member
    Poland
    Installing the fan controller for PRIUS 30
  9. AzusaPrius
    2,257
    942
  10. ASRDogman
    ASRDogman Senior Member
    8,065
    4,086
    So, the conclusion: Find out WHY the battery is over heating, then correct it.
    No extra devices needed.
    Perhaps a few cells are swollow which blocks air flow. :whistle:
  11. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    I'm so glad this thread came back up. Needed a good laugh today!!
    PriusCamper likes this.
  12. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    US $320.- ......
  13. PriusCamper
    PriusCamper Senior Member
    13,459
    5,430
    Pacific Northwest, USA
    Lol... Not a day goes by that I don't see someone scamming people on car stuff...
    PrimeFactorE and Grit like this.
  14. ASRDogman
    8,065
    4,086
    OUCH!!! Lot's of money!
  15. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    heck, at that price someone here will probably buy 3 and get the rest of us a discount code! Jump on it, dawg!!
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I think the guy with that runs his Prius online shop pc name beginning black will then claim to buy 3 and not ship it out but will charge ya
  17. darknd666
    darknd666 Junior Member
    174
    23
    Jacksonville, NC
    A peltier plate hooked to a solar panel, it would be the most efficient. The fins of the plate would cool the air as it goes by. Just a theory.
    Hooking it up to the 12V system may have detrimental effects to MPG and the battery system. Besides if there is ample sun then it likely would need the extra cooling benefit.
  18. darknd666
    174
    23
    Jacksonville, NC
    In regards to repelling heat, would there be any advantage to installing a radiant barrier material in the roof under the headliner?
  19. PriusCamper
    13,459
    5,430
    Reflective barriers over the windows would be more effective... And repelling heat from roof would best be done by color of paint on roof or modifying outside of roof with reflective material because there's not much room between roof and headliner to change thermal loading much and it will likely lead to headliner headaches as time goes by.
    darknd666 likes this.
  20. darknd666
    174
    23
    Jacksonville, NC
    That was a theory I had in my head, that the science behind insulation and rejection would be futile. I guess I could invest in a ceramic coat on the exterior of the car. I have already installed a ceramic tint and that made a huge difference, im just trying to maximize heat rejection, or at least slow it down.
    The biggest disadvantage I have is the car is black...
