Hybrid Battery Driving Charge/Discharge Cycles
Discussion in 'Gen 3 Prius Technical Discussion' started by Dave1UK, Jul 5, 2026.
  1. Dave1UK
    Dave1UK Junior Member
    92
    London, UK
    Active
    So after having my hybrid battery fail, I am trying to theorise whether my driving habits and actions had an impact/maybe make some improvement suggestions?
    The hybrid battery I had was a reconditioned replacement, it came with 6 months warranty, lasted 18 months.
    In terms of my driving habits, I don't do many motorway miles, about 20 miles weekly? All of my driving is city driving start/stop. I've covered a total of about 9,000 miles with that battery.
    What I actively have been doing though since I've owned the car is intentionally engaging the EV mode not via the EV button. For example once I get up to speed (30mph) then let off the pedal slightly, this engages the EV mode, I cruise on it if possible completely depleting the battery. I don't actively/unnecessarily brake trying to regen though. Is this something others do as well? Is that better for the battery or wears it out more?
    I averaged 55mpg over 4,000 miles according to the ODO.
    Another point is my AC hasn't been working properly since I owned the car and the past few weeks with heatwaves by UK standards (35 degree Celsius outdoors), driving the car even with windows down, probably hasn't had a good impact on the battery itself as it wouldn't have had sufficient cooling, even though the fan is dust free and verified it works properly.
  2. ASRDogman
    ASRDogman Senior Member
    8,069
    4,091
    VERY few have had success with used batteries.
    UNLESS you KNOW they were from a wreck car that had a good hybrid battery.
    People/business's grab worn out packs and pull the betters blocks out and assemble a
    complete pack. They MAYBE they use the Prolong system, or something similar, and do the charge/discharge
    cycles and deem it "good"
    Then pawn them off on unsuspecting people like you. It should be illegal, but it's not.
    You'll spend more money, and time, trying to keep it going then if you bought a new Sodium Ion battery.
    You don't drive a lot, so that will effect your 12v battery. You might want to get a 5 amp or less AGM
    charger/ maintainer to keep a full charge on it.
    The a/c on a Prius is very touchy. You should find a Toyota Prius specialist and have them look at it.
  3. Dave1UK
    92
    London, UK
    Active
    Yes I have realised that's how people/businesses operate in that regards, that's why they want your old hybrid battery pack in exchange for a slightly lower cost to harvest the "good" cells and sell it on.
    However nobody sells Sodium-ion battery packs here in the UK, unfortunately still behind.
    Indeed after I fix the battery will get the AC looked at.
  4. ASRDogman
    8,069
    4,091
    Contact Jack, Perhaps he could get one to you.
    I don't see what the issue could be for shipping you one.
    They're not dangerous like lithium batteries....
  5. CR94
    CR94 Senior Member
    2,837
    1,244
    Northwestern S.C.
    Whereas I do the exact opposite, trying to avoid that situation in which you're cruising (albeit at relatively low power demand) for extended periods on energy from the battery. You aren't really "completely depleting the battery," but are needlessly (in my opinion) draining it to the extent the management software allows before starting the engine to recharge. Doing that once in a while does no significant damage, and is hard to avoid, but I wouldn't deliberately do so frequently.
    I've averaged about 59 mpg(US) over 127k miles with no obvious loss of battery capacity.
    #5 CR94, Jul 5, 2026
  6. ASRDogman
    8,069
    4,091
    I sent a text to Jack asking about shipping to the uk, this is what he sent me:
    "I just checked, we ship worldwide via FedEx ,
    perhaps their shipping address is too rurual and FedEx can't reach."
    This is his handle here: jacktheripper
    Toyota hybrid battery upgrade pack– NexPower Energy
  7. Dave1UK
    92
    London, UK
    Active
    Yeah aware it doesn't completely deplete it, meant before engine kicks in for regen/you regen via braking. Just wondering whether maybe my driving habit in general isn't good for the battery.
    VelvetFoot likes this.
  8. VelvetFoot
    VelvetFoot Senior Member
    1,408
    546
    New York State
    2026 Prius
    Gen5'er here. Also interested.
    CR94 likes this.
  9. Dave1UK
    92
    London, UK
    Active
    Just to add, maybe actively engaging the EV mode (as I described in my opening post) this of course depletes, and then forces engine to kick in/regen the battery via braking etc. so this "cycling" would directly impact the batteries lifespan in general. Then to add to it, this also generates heat of course. So theoretically, if you're doing that more often consciously than someone who doesn't I guess it would cause more wear overtime? However then again isn't that the whole point of a hybrid squeezing out as much as you can and its intended purpose?
