Hybrid Battery Failed - 2012 C
Discussion in 'Prius c Technical Discussion' started by RobAustin, Aug 3, 2018.
  1. RobAustin
    RobAustin Member
    104
    52
    Austin, tx
    Update:
    Picked my car up from the dealer, (their final offer $2,700.)
    Happily, a friend offered to help, and the swap took just under two hours.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Should be $0.00 for you since, as @Rmay635703 said, it's still under warranty.
    pleasedpriusowner likes this.
  3. RobAustin
    RobAustin Member
    104
    52
    Austin, tx
    Cknitin, model C has a much smaller (0.9kw/h) battery than the regular Prius(1.3) It might be unrealistic for us to expect them to last as long as their big brothers.
  4. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    Congrats on the find... pic
    RobAustin likes this.
  5. RobAustin
    RobAustin Member
    104
    52
    Austin, tx
    Pics of the 2016 salvage battery pack I bought from LKQ in New Braunfels.
    Raytheeagle and dubit like this.
  6. padroo
    padroo Senior Member
    2,763
    2,253
    I don't know much about the Prius C but if the battery pack is made with the same high quality battery cells Toyota uses in the standard Prius and the same battery management system I see no reason why the C should be a shorter life battery.
    With a smaller lighter car and probably fewer cells it should last longer would be my guess. The fewer cells would be less chance of one failing. This is just speculation on my part.
    a400ryan and bisco like this.
  7. bisco
    52,662
    i agree. some batteries just fail sooner than others. it could be a factory defect, or a myriad of user factors. heat is one enemy.
    padroo likes this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    The cells are the same, there is just less of them;).
    The weight of the c is also less, so less mass to move so it might be proportional.
    What I’d do rather than get the $250 core charge is sell the good modules for a profit:).
    You’ll get more than $250 back and help someone else out(y).
    padroo likes this.
  9. RobAustin
    RobAustin Member
    104
    52
    Austin, tx
    You’ll get more than $250 back and help someone else out(y).[/QUOTE]
    I would like to help someone else. I'm feeling grateful to PrusChat for everyone's guidance so far.
    Has anyone disassembled a C battery pack or tried to repair one? I didn't see any PriusC specific guides...
    If you guys are interested let me know, I still have a few days to decide.
    Rob
  10. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Based on that printout, block 3 has one module out, so you have 19 to sell;).
    To disassemble is not that hard, and all you need to do is have a multimeter to find the bad actor. If you put them up on eBay (or Craigslist) and ask $30 a module, that would be $570 you could obtain and then assist others:).
    There are plenty of YouTube videos on pack disassembly;).
    Good luck and keep us posted (y).
    jerrymildred and padroo like this.
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I always tell people seeking "goodwill" support to try...but not expect anything. Technically...it is past warranty.
    But that is a somewhat surprising response from Toyota.
    With only 18,000 miles above warranty, and only 6 years. I've definitely read of more extreme cases beyond warranty where Toyota in the past has stepped up and offered some level of goodwill support.
    That seems like a premature failure of the battery by regular Prius standards. And hopefully it's not indicative of a reality in general with Prius C.
    I bought my Prius in CARB state. And I fully expected at the VERY least 10 years, 150,000 miles...and that was only as the minimum warranty coverage expectation. I was honestly hoping for and expecting more.
    I would be very disappointed if I only got 118,000 miles and only 6 years.
  12. RobAustin
    RobAustin Member
    104
    52
    Austin, tx
    My first post was wrong, it failed at only 115,000 miles.
    Rob
  13. Al Bundy
    Al Bundy Member
    140
    69
    florida
    WOW this is all news to me about the prius C being this bad...
    I thought all the batteries were the same as the regular prius and the body was different..
    this does explain why a local courier company in Tampa is selling 2012's & 2013's for under 7 grand..
    I was going to look at one next month as my 08 is getting up their in miles ..
    sorry yours failed and toyota will not stand behind it..
    guess i will not be buying a newer used prius..
  14. RobAustin
    RobAustin Member
    104
    52
    Austin, tx
    The repair cost me $879 for a salvage 2016 battery. And the Install took less than 2 hours.
    Rob
    Raytheeagle and jerrymildred like this.
  15. jerrymildred
    11,517
    14,164
    Tampa, FL
    Sounds great!! I assume this is non-refurbished?
  16. Al Bundy
    Al Bundy Member
    140
    69
    florida
    good luck with it
  17. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    LOL. Here in Japan, the Aqua is rated as the most reliable car...ever. Yes there are "early" battery failures, mostly in high heat/high humidity areas. Just like there are early failures of engines and transmissions, and other expensive parts in just about every car out there. Here on Prius Chat, you don't get the macro view of the overall picture.
    But what really perplexes me is how the dealers in the US charge so much for a C battery replacement. Here in Japan, there's a big rebate on the used core, and a new battery + install at any Toyota dealer runs just under $2,000. Even in the US, it's $2,588 retail for a new Toyota battery plus a couple of hours labor. How does that come out to close to $4,000?
    This is not a Toyota problem, but a dealer problem. As I keep telling people...find a good independent that specializes in Toyota Hybrids, and take ALL of your business to them. Except for warranty repairs, stay away from the dealer, and always turn down their suggested wallet flushes, should you need something fixed under warranty.
    jerrymildred and dubit like this.
  18. Matt H
    164
    105
    Okinawa Japan
    2012 Aqua
    So once they realized you were going to take your business someplace else, suddenly the price is $1,100 cheaper? We talk about this in automotive shop management circles, and what it tells me is the original estimate was $1,100 over the price necessary to be profitable.
    Not sure how the system works there, but I'd file some kind of complaint against the dealer with Toyota. Probably nothing they can do, as the dealers can set their own price on customer pay, but Toyota does keep records on this kind of thing. When the dealers start making the brand look bad, things will change.
  19. Al Bundy
    Al Bundy Member
    140
    69
    florida
    I had a Chevy HHR SS when all the recalls started a few years ago, the same service adviser that greeted me with a big smile everytime I took the car in for service looked at me like a POS and told me that the cobalt & hhr SS had so many parts under recall that it could take 7 months to get everything needed, they would not start the work until all parts were in stock and the car wasnt safe to drive and gm would not give me a loaner or buy back the car unless i wanted black book wholesale.I contacted GM and they said the dealerships are independently owned and each dealer is handling the recalls on a case by case basis . All brands are the same, its all about the profit
  20. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Sorry to hear about your HHR. We were talking just the other day about how quickly those were disappearing out on the road.
    But having worked for a GM / Toyota dealership at the time. I was there when the Oldsmobile Bravada was just hitting the dealerships. It came out first, before the Trailblazer & Envoy. I don't remember the reason why, but a recall was issued for it right after it came out. It was also listed as "unsafe to operate". GM did in fact offer to buy back the vehicle at purchase price paid. But it's the only vehicle I can ever remember where GM (or Toyota) ever purchased them back from the buyer. There may be others, but for the life of me I can't remember any. I have however seen both companies buy one back on a "one on one" basis due to individual reasons.
    As for "Loaner" cars that we typically hear people demand when their vehicle is in for service. That's up to the dealer to provide. All those new cars you see on the lot are not owned by the manufacturer as most people think. Rather they are typically property of the bank the dealership utilizes to do it's payroll/operational costs. We tried the 'loaner car" route at our dealership, but found it to be so much of a "money suck" that the dealership bordered on being non-profitable. So we dropped it, and for awhile, utilized Toyota's Rental car program - aka TRAC. But that program was difficult to manage. Often a persons vehicle insurance company will provide a "rental car" while their vehicle is being serviced. Knowing this, we remodeled an area of our service department, and rented the space for free to "Enterprise Rental Car". It's still there to this day.
    {edit} - wanted to add that all business though are "in it for a profit". They can't exist any other way.
