Hybrid Battery fan cleaning?
Discussion in 'Newbie Forum' started by PriusToo, Jun 12, 2014.
  1. PriusToo
    PriusToo Junior Member
    84
    Charleston, S. C.
    Was wondering if there is a simple way to inspect and clean hybrid battery fan.
    I'm not having any problems, just would like to keep it maintained.
    My car has over 150k
  2. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    It isn't easy to get at and that's the only way you can inspect it. By the way, if you do remove it to clean it and you use compressed air don't allow the fan to spin, especially in the reverse direction, as you may burn the motor out.
    Woodstock74 likes this.
  3. PriusToo
    84
    Charleston, S. C.
    Thanks for the advice, goes without saying to disconnect the 12 volt battery also.
  4. Feri
    Feri Active Member
    761
    144
    And Start switch off. Always a good idea!
  5. PriusToo
    84
    Charleston, S. C.
    When you say start switch off, you mean just the fob not in car???
  6. bisco
    52,762
    no, just don't power up the car.
    if you haven't carried fury pets and the like, there's really no need to inspect it.
    #6 bisco, Jun 12, 2014
  7. Mendel Leisk
    42,250
    You shouldn't need to disconnect the 12 volt.
    I've dug down to ours, 3rd gen. Didn't actually pull it out, just got close enough to see the inside was clean. The main hassle was sorting out how to pull the covers and panels off, without destroying fasteners.
    I subsequently put a piece of vacuum cleaner motor filter material behind the fan's air intake, and just keep an eye on that, pull it out clean it occasionally. It's looking pretty clean. Once in a blue moon we transport a dog, but that's all.
    xpcman likes this.
  8. PriusToo
    84
    Charleston, S. C.
    Thanks again, I think it has been a pet free car.
  9. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Why would this burn out the motor ?
  10. Feri
    Feri Active Member
    761
    144
    Apparently it generates a current and particularly reverse direction can cause problems. Additionally the compressed air causes serious over revving. You can damage computer fans the same way.
    Daves09prius likes this.
  11. jejb
    jejb Member
    95
    27
    NW Ark
    2016 Prius v wagon
    I burned out a laptop fan once letting it spin while I cleaned it with our air compressor. Learned my lesson on that one.
    I've heard that you can get pre-filters for the intake fan. We will have dogs in the car often, so would like to get some of those. Are they custom jobs I'd make for myself, or does someone sell them? Thanks.
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Have had the fan out removed the bearing label and oiled the motor bearing. 3 in 1 oil made for electric motors found at Lowes. Same stuff you use on your home ac compressor fan. Never seen a fan burn out from reverse direction with air compressor and do it all the time.
    Go to Home Depot and buy thin filter media. Buy double sided heavy duty tape. Ring the outside filter cover with the tape. Cut media to fit. Press media onto tape. Good for years.
  13. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    While filters are a good idea, be careful that you do not get an overly-restrictive filter.
    Especially if you live in a hot-climate area.
    Restricted air flow is just as bad as a dirty/clogged fan.
  14. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Hence the thin media.
  15. DrPepperholik
    DrPepperholik Active Member
    342
    109
    Spartanburg, South Carolina
    What kinds of filters would be recommended? I have a German Shedder and while I don't plan on toting her everywhere I go there will be a significant amount of hair in my car.
  16. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
    You could probably use the replacement window a/c type filter pads or the filters they sell for floor vent registers.
    HTC Evo 3D
  17. Feri
    Feri Active Member
    761
    144
    See edthefox5 above and heed ericbecky's warning.
    DrPepperholik likes this.
  18. PriusToo
    84
    Charleston, S. C.
    This is all good to know, appriciated all the input from everyone.
  19. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    nylon stocking
  20. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Hey nylon stocking is a great idea. Thanks!
