hybrid battery fan doesn't seem to come on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dale I, May 16, 2026.
  1. Dale I
    Dale I Junior Member
    38
    Point Arena,Ca.
    on my 2004 Prius...I have a clean fan with air filter installed. I've tested relay and made the fan run in both speeds with my Consulit code checker. Yesterday the red triangle came on with P3000 code. Battery was up to 90F after sitting a half an hour. Fan did not run. I had, previously, checked the notorious fan connector for corrosion and renewed that with waterproof connectors. I checked all the battery modules and they were all 16.4 or 16.5V. Resistance was close to the same in all modules. I had the battery out 6 weeks ago and replaced one module pair that was a little weak. What direction to go?
  2. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    If you can make the fan run with the Toyota software or some software and a scan tool then the fan runs and is capable of turning on so maybe sensor I v that duct work that aluminum thing I that duct work may not be sending the temp if air correctly ?
  3. PriusCamper
    PriusCamper Senior Member
    13,467
    5,436
    Pacific Northwest, USA
    My best guess is sometimes a P3000 doesn't shut off the hybrid system and go into full limp mode, which runs the fan at full blast. Maybe use hybrid assistant app to keep the fan running at full speed when you're driving to confirm Consulit code checker...
  4. JC91006
    16,936
    8,647
    I'm not sure the fan suppose to turn on at 90F, that's a really mild temperature reading. You need to find out what subcodes go with P3000. To point you to a better reason of why the triangle is on. I would suspect the pair you put in 6 weeks ago is probably the reason for the triangle. But that's just a guess
  5. Dale I
    38
    Point Arena,Ca.
    thanks for the quick replies....
    The reason I changed out the module set 6 wks ago was due to a red triangle...
    I've replaced modules before and generally they work if voltages and resistances are correct.
    The car ran for a couple of thousand miles before this latest incident. Since I wasn't driving the car
    when this incident happened (wife), I don't know if the fan had been on. Since my scanner showed the
    battery temps, I assume the sensors are conveying info to the ECU. I tested the relay on my relay tester and
    it passed the test. I live on the coast in a mild climate, so generally I think the battery stays cool. I'll have to drive it
    again and do a freeze frame to see if anything faults show, at the incident time. At what temp should the fans come on?
  6. JC91006
    16,936
    8,647
    I don't know when the fan is suppose to come on, but I would think it would be higher than 90F. Your problem should not be related to the fan.
  7. Dale I
    38
    Point Arena,Ca.
    I'm going to put it back together, drive it till it screws up again, freeze frame the data and go from there.
    I'd love a new battery but....
  8. JC91006
    16,936
    8,647
    There's a lot of value in a newer battery. Think of the safety and time aspects. How much is that worth?
    There are many places that are selling slightly used batteries for about $1000 (possibly from 2023 or newer). You can buy one of those (camry, rav4, sienna, Prius), whichever one is cheapest in your area. Swap all the modules to your car/case. And then you'll have a reliable battery for 10 years
  9. Dale I
    38
    Point Arena,Ca.
    any rebuilt battery sellers on the U.S.A.West Coast, that can be trusted?
  10. JC91006
    16,936
    8,647
    not many rebuilt batteries can be trusted, they would be exactly what you have now. What I was referring to was buying a used battery, OEM part that has all the modules that were produced at the same time. Not batteries that were put together from all different batteries
  11. PriusCamper
    13,467
    5,436
    This guy sells the best modules for rebuilds. Also sells fully rebuilt packs too... He teaches Hyrbid & EV repair at his local community college and has spent tens of thousands several times on lab-grade battery testing gear over past 20 years: Manage Hybrid Battery Purchases Easily Online
  12. Fred_H
    Fred_H Misoversimplifier
    562
    488
    28
    Germany
    I once did some data logging, and came up with this:
    HV battery fan speed transition temperatures
    Fan
    Speed @ Temperature
    0 to 1 @ 36° C
    1 to 0 @ 34° C
    1 to 2 @ 39° C
    2 to 1 @ 37° C
    2 to 3 @ 42 °C
    3 to 2 @ 40 °C
    3 to 4 @ 50° C
    4 to 3 @ 48° C
    4 to 5 @ 52° C (current limit reduced)
    5 to 4 @ 50° C
    5 to 6 @ 56° C
    6 to 5 @ 54° C
    Google AI Fahrenheit conversion:
    "Fahrenheit Temperature Table (1 Decimal Place)
    • 0 to 1 @ 96.8°F (36°C)
    • 1 to 0 @ 93.2°F (34°C)
    • 1 to 2 @ 102.2°F (39°C)
    • 2 to 1 @ 98.6°F (37°C)
    • 2 to 3 @ 107.6°F (42°C)
    • 3 to 2 @ 104.0°F (40°C)
    • 3 to 4 @ 122.0°F (50°C)
    • 4 to 3 @ 118.4°F (48°C)
    • 4 to 5 @ 125.6°F (52°C) — current limit reduced
    • 5 to 4 @ 122.0°F (50°C)
    • 5 to 6 @ 132.8°F (56°C)
    • 6 to 5 @ 129.2°F (54°C)"
    #12 Fred_H, Jun 7, 2026
  13. PriusCamper
    13,467
    5,436
    It'd be interesting if you could log these numbers again based on vehicle speed. It's been mentioned on here that a key design of this fan so you don't hear it is to correlate a faster more noisy fan with faster vehicle speed/road noise.
  14. bisco
    52,863
    wouldn't that be really bad for the battery?
  15. PriusCamper
    13,467
    5,436
    Can you elaborate? I'm not clear on what you're saying?
  16. bisco
    52,863
    say you're in stop and go traffic on a highway at 120f, fan is running slow to keep noise down. good idea?
  17. rjparker
    rjparker Tu Humilde Sirviente
    11,119
    6,976
    Texas Hill Country
    Bisco is saying this flawed logic would be "really bad for the battery". The obvious conclusion is Toyota does not do it.
    As far as the Op's P3000, he needs a better code reader to get the Toyota specific codes / sub codes, to determine why the generic P3000 was output. Then solve the issue instead of priming the parts cannon.
    #17 rjparker, Jun 7, 2026
    Brian1954 likes this.
  18. PriusCamper
    13,467
    5,436
    It's a good idea when you're selling a brand new car to some super uptight person who complains because their brand new car is too noisy. But when it comes to taking care of your aging battery pack and being made aware of a cell that's running hot and heating up the pack under normal driving conditions its a terrible idea.
