Hybrid battery fault
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Amadeus06, Jun 23, 2018.
Tags:
  1. Amadeus06
    Amadeus06 New Member
    Greece
    Hi
    This is my first post here and i want to share problem i have with my 2006 Prius.
    Recently i have replaced the Hybrid battery but after about one month i got again Hybrid battery fault error.
    The car became heavy and i forced to visit again the technician.
    In short with in a period of 2 months i have the same problem for four times.
    Today is the fourth time i get the same error.
    Every time i visited the technician he told me that he replaced some of the hybrid cells.
    Of course i have a serious doubts about the technicians credibility now, but just in case is there something besides the hybrid battery problem that can cause the same error. ?
    Thank you
  2. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    When you use a battery that has cells from a different battery, different year manufacture, different mileage, etc. you will likely get what you are seeing. It's a bad idea if you plan to keep your car for longer than a few years. You are better off getting a new battery or a late model pack from the junk yard and putting them into your battery case.
    SFO and bisco like this.
    49,380
    welcome!
    ^^^^^^^^^ we call it whack-a-mole.:cool:
    Raytheeagle likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    It can be played successfully with the right equipment ;).
    Simply replacing cells is a lot of work as the OP is finding out:(.
    Charging and balancing after module swaps gets a lot more for your effort:).
    Good luck and keep us posted (y).
  5. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    Welcome! I spent about 4-1/2 months over 7 trips in Halkida, when our company was working with HAI in Schimatari. Saw a lot of your country, as we were out every weekend. :)
    At a minimum, I wouldn't use the same technician, just in case he is just resetting the error code, or replacing the wrong modules. Four times in 2 months seems like a lot of repeats, even for whack-a-mole.
