Hybrid battery is dying, unsure which way to go
Discussion in 'Gen 2 Prius Technical Discussion' started by liberate88, Jun 18, 2022.
  1. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    The long trip home and through the mountains without a working battery probably stressed the little ICE enough that you should check and change the oil asap
    ColoradoCrow likes this.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,159
    6,316
    Texas Hill Country
    There is no way to guarantee reliability with a used battery that is 10-18 years old. When is the last time someone offered to sell you a "refurbished" 12v battery? Traditionally we were satisfied to get 3 or 4 years out of the 12v. You can put a magic "reconditioner" on the old 12v battery as well. Does not work.
    Sure you can break up a Prius hv battery and swap the worst modules. But plenty of people will experience downtime multiple times over a year or two. Reliability in a vehicle is more important than a replacement guarantee. Does not matter if "BlueTech" will swap it again (after a seven day wait assuming nothing else in the car is bad - read the disclaimers). Some of the refurbishers won't even return calls after the first failure.
    That brake actuator code is concerning as well.
  3. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    463
    Leawood, KS
    I
    Is the rest of your car in good condition? Paint, frame, window seals, Tires, suspension, etc? Do you like your car and want to drive it for another 4 years? Is it paid off? If it IS paid off....and you said yes to all of the above a $2,000 investment into your car for a NEW Battery makes sense. That is about $45 a month for 4 years. Well worth it. If you said no then what are your options? Cars are so expensive right now. I have an 08 with 119K and I plan on keeping it for 4 more years so a new paint job and new hybrid battery make sense for me.
  4. Z50king
    Z50king New Member
    Socal
    You can get a Lifepo4 battery for 400 dollars more than that OEM battery
  5. liberate88
    liberate88 New Member
    23
    Idaho
    mostly yes, she’s a little dinged and I need to reseal the hatch for water leaks, but I just bought new tires and she checked out at the mechanic for the most part.
    how do I only spend $2,000 on this repair? One shop I spoke to quoted $4k. Do I need to do the install myself to keep it in the $2k range? Will this website have what I need to find the best way to buy the new battery and install it?
  6. rjparker
    10,159
    6,316
    Texas Hill Country
    Being in Idaho limits the options somewhat unless you are heading to Washington state or somewhere else where Prii roam free.
    Staying under $2k may require ordering new cells from newpriusbatteries.com and having a skilled diyer or a local mechanic install them. Right now it looks like they are backordered into August.
    Or gain mpg with a few more dollars with a $2240 kit from projectlithium.com. Also backordered but this is the way I would go when the time comes again.
    But I probably won't have the need since I already changed to new Toyota a few years ago for $2250 installed. Still available for $2,295 with free round trip shipping from Free Shipping Gen2 Prius to the Lower 48 | Hometown Hybrids. In Texas they install free.
    The Toyota dealers have a wholesale cost of less than $1600. A dealer in Florida was selling them on sale for $1600 a few months ago. The point here is knowledge is power and some dealers will negotiate. Some won't. It is about a hour job for guys who know how.
    #26 rjparker, Jun 23, 2022
  7. liberate88
    23
    Idaho
    i haven’t- could this eliminate problems or based on codes it’s not causing the issue and I can clean when I replace battery?
    rayluo likes this.
  8. liberate88
    23
    Idaho
    thanks for all that! Who is the “they” in they install in Texas for free. You ordered from that site and who did the free install?
  9. rjparker
    10,159
    6,316
    Texas Hill Country
    The supplier.
  10. DarkAlaranth
    DarkAlaranth New Member
    Townsville, QLD Australia
    Kind of looks like the bank 12 has an issue in the pack, high resistance. P3022 also flags 12 as a weak bank.
    If water ingress has occurred, then it might just be corrosion on the battery terminals causing a poor connection. A high resistance at the terminals would cause the battery to charge less, and deliver less, making it look weak.
    Could also be an actual dead bank.
    NI-MH batteries usually are around 29ohm in the Prius, and Jack's Lithium packs usually sit around 19ohm.
    If you know someone capable, or a willing to do more research BEFORE opening the battery.. it might save a lot of cash to check for corrosion. The pack might still need to be balanced though afterwards, as bank 12 hasn't been charging/discharging the same as the other cells and might be out of sync with the other cells.
    If you want/need to replace the cells, I can definitely recommend jack's batteries (Nexcell Lithium replacement at project lithium's website) - Worth the wait, if you can wait. :)
  11. bisco
    51,953
    yes, it is one possibility
  12. Another
    1,819
    517
    Naples, Florida
    Maybe head south to Salt Lake City
    Seems there are many battery installers there
  13. ColoradoCrow
    1,108
    463
    Leawood, KS
    I
    Yes the $2,000 Price tag includes installing it yourself. There are several you toob videos showing the process. Watch several of them. If you feel you can.t do it. Ask a friend who is skilled at DIY and have them watch the videos. Many videos on cleaning the hybrid fan. Do the same with this job. If not ask on the forums here. Somebody near you will know someone who should be able to help you out.
  14. liberate88
    23
    Idaho
    487B3ACC-39A4-4679-A450-B990AAA3EBE9.jpeg A2AF78EE-3042-4DF9-B0DD-4A064C63DC92.jpeg 99D73C81-A610-4AA0-9519-31C7F68F0C0E.jpeg 4014F4BF-BF3A-4770-94D2-78D69E84BB55.jpeg 07CFE0BE-26AA-4F32-9A5E-18C9843A088A.jpeg 85019DEE-795C-4F7E-A101-A647FA2FBAB6.jpeg
    Okay I did some investigation. There’s one photo of something I’m confused about, it’s a black rubber type tube not connected to anything next to the 12v. And some pictures of the fan. I’m curious some parts dont seem connected well like the outlet of hot air from the battery pack and to the outside as well. The exit of the fan to the airflow going into the battery pack doesn’t seem like a great connection either, and there’s some foam around that, but maybe it all “floats.” The airflow filters are obviously dirty, I should have picked some up before doing this. And the fan is dusty, as I expected living on dirt roads in Idaho, but doesn’t seem overly clogged (I am going to clean it). Also, the well of the 12v is embarrassingly rusty. I haven’t yet opened the battery pack because I’m nervous and want support from a friend.
    I also want to add that the mpg is very, very low, it’s eating gas like a truck, particularly when I have to do more stop and go. If the driving is more consistent sometimes the battery charge goes to two bars, but that’s very rare.
    The dealership in Twin Falls quoted me $2600 for a new battery pack, parts and labor. I don’t feel prepared to do the work myself as prior to this the only thing I’ve done for my car is change the cabin and engine air filters. It seems reasonable? Other options looked to be in the $2k range for the parts. Before going that route I am going to peak at the battery for corrosion.
    also, fuse to the fan corroded?
    #34 liberate88, Jun 25, 2022
  15. liberate88
    23
    Idaho
    so it sounds like even if it were a corrosion problem that I could somehow fix on my own, the battery would still need some tlc?
  16. bisco
    51,953
    the tube vents the 12v. someone put a rogue battery in, with no vent apparently, unless you see one to plug the elbow into. unsafe in a rear end accident, but many people ignore it.
    there is no vent to the outside, it just exits under the 12v with a one way rubber valve.
    clean the corrosion first, clear the codes and see if they come back. $2,600. for an oem is a very good price.
    DarkAlaranth and liberate88 like this.
  17. liberate88
    23
    Idaho
    Thanks! I'll check for a vent, maybe it just came out when we had to jump it a few weeks back.
    Would corrosion cause all the problems? I could see how it may effect the fan intensity but what about the battery pack not charging? Or if the battery is corroded in certain areas that can cause it not to charge? If that is the case, what is your opinion on needing it balanced? Someone else said that even if I repaired the possible corrosion that it may need some attention still.
    Thank you for staying with this thread for me!!!!
  18. rjparker
    10,159
    6,316
    Texas Hill Country
    The fan blower wheel is seriously clogged. Hopefully you cleaned it. $2,600 for a new dealer battery is certainly better than the $4k quoted in post 25.
    However your bearing(s) in post 1 and the brake actuator code in post 5 should be considered as well. The bearings could be $400 a wheel, not bad if its just one. The brake actuator might be $2,500 by itself and is a safety issue. You notice Dr Prius can't read those codes. I would want to know what may be coming after the $2,600 battery.
  19. ColoradoCrow
    1,108
    463
    Leawood, KS
    I
    Yes. That is a good price on a new battery. Definitely clean the fan. I would remove it from the car and use a lot of q tips and isopropyl alcohol to super clean it. Also you should remove and clean the inside and outside of the duct work. I use a old camelback bottle brush or a rag ziptied to a short stick and scrub it clean. Since you life on a dirt road I would check it yearly and clean as needed. More if you ride with the windows down and have pets that shed fur. This cleaned hybrid fan will keep you old and eventually new battery as cool as possible. I try to keep the inside of my car no hotter than 85 degrees. So I run the AC a lot but I'm ok with the MPG loss. Wheel bearings are important to go....ABS module is important to stop....I'd for sure work on those next. Electrical contact cleaner and a toothbrush work wonders on electrical connector. Clean and then spray with canned air or let air dry for awhile and then reconnect.
  20. bisco
    51,953
    the corrosion on the fan plug is very common, and can wreak havoc with the computers. get that done first.
