Hybrid battery issue
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bubba King, Jun 28, 2020.
  1. Bubba King
    Bubba King New Member
    Lakeland FL.
    I have a 2010 Prius giving me a replaced hybrid battery. I have checked voltage in each cell 7.5 + voltage in each cell. Drained batteries done trickle charged each on still holding voltage. Reset error few days later come back again checked voltage again. All good . Cleaned all copper plates for corrosion. Still every few days it comes back any ideas. Before I go and replace $2500 hybrid battery . Thanks
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,000
    6,894
    Texas Hill Country
    First I would get some more hard data including identification of which cells are out of tolerance. Then I would consider changing those if I was not ready for new cells, which, in my opinion, is the only way to go if you want a reliable car. There are options at $1600 for new cells or around $2250 for a new Toyota battery. The pic shows my 2012 Prius v wagon using “car scanner” app recently:
    AzusaPrius likes this.
    52,773
    read the rebuilding/balancing threads if you want to bring it back to life and deal with issues as they come. otherwise, pick up a 'newpriusbatteries.com' for $1,600.
  4. AzusaPrius
    AzusaPrius Senior Member
    2,251
    940
    You can also check out green bean batteries. They have a lifetime warranty and it is transferable when you sell your car. $1650 for your car or do the job yourself and save all that money.
  5. ASRDogman
    ASRDogman Senior Member
    8,042
    4,075
    How old is your 12v battery? What is the voltage?
    A weak or bad 12v battery can throw all kins of hybrid errors...
    I would check that before thinking you need a hybrid battery.
    pjksr02 likes this.
  6. Dr Strangelove
    Dr Strangelove New Member
    Nj
    Which app did you use for this data if I might ask?
  7. rjparker
    11,000
    6,894
    Texas Hill Country
    “car scanner”
  8. Dr Strangelove
    Nj
    Thanks
  9. Marcus Johnson
    Marcus Johnson New Member
    Glen Burnie, MD
    You should go to the dealer and ask if they could check with Toyota to help with the expense. I just had my hybrid battery replaced, and now the AC button is not working.
