hybrid battery level with a Obd2
Discussion in 'Gen 3 Prius Main Forum' started by Wobblybike, Jul 19, 2025.
  1. Wobblybike
    Wobblybike Junior Member
    23
    Los angeles
    Hello....I did a scan with car scanner on the battery pack and 7 cells show an average of 16.6 and the other 7 show 17.1. However the car had not run for a couple days. Can that be normal as I've been reading that the up and down level can happen when the car has been parked for a while. I will try again after a little trip and see. Meanwhile I would like to hear from the pro's on this forum. thank you in advance.
    Prius 2010
    Mileage 119K
    All liquids changed with toyota brand.
    Burns one quart of oil per 800 miles
    52,855
    clean the egr circuit if you haven't
  3. Wobblybike
    23
    Los angeles
    How is that done? Does it affect the charge differential? Thanks
    52,855
    no, that was a complete aside to help prevent blowing the head gasket. i'm not an expert on battery charge levels. here are a couple informative links on the egr circuit: search
    758597279
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Thread hi-jacked in record post!!!
    bettergolf and Brian1954 like this.
  6. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    A guy spoke to me at the gas pump yesterday, asked the year and mileage of my Prius. (2015, 114k). Told me his is a 2013 with 289k...the ONLY thing he has done was a water pump (it was overheating) about 70k ago. He took it to the dealership when it overheated. and was told he needed a new engine. Ha! No oil burning, no head gasket failure. I suspect there are thousands more out there like that........
