Hybrid battery load test and intelligent tester have different results
Discussion in 'Gen 2 Prius Technical Discussion' started by sushiho160418889, Mar 18, 2018.
  1. C Wagner
    C Wagner Member
    183
    60
    Boston
    Here's the full wiki on charging, replacing, rebalancing, conditioning etc. I'm not an expert, just someone who went through it after reading the 'summery' and did a write-up. Good luck. Do get yourself a hobby charger, don't use a standard lead acid battery charger.
    You can also find this above in the menus under Wiki...
    Prius High Voltage Battery Reconditioning | PriusChat
