Hybrid battery looses charge.
Discussion in 'Gen 3 Prius Technical Discussion' started by katiesdad7, Apr 13, 2011.
  1. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Say what???
    :confused:
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Did you add a high voltage solar charger? The PV panel on the stock Prius is only used to power a ventilating fan. It does not charge anything.
    As for lower SOC when parked at school, there are two likely causes:
    1) Hot or cold parking lot, which reduces the effective SOC.
    2) Leaving your Prius in Ready. This will run down the HV battery, as the ICE will run only enough to keep it partially charged.
    Tom
  3. richard schumacher
    7,683
    1,066
    United States
    katiesdad, are you *really* sure that the car is off? Maintaining 2 bars is exactly what the car does when it is Parked and ON. Lock it every time you leave it; the absence of any warning beeps will assure you that it is off.
    As other wrote, if it really is off and this still happens then yes, there is something wrong with the car. Take it to a different dealer for diagnosis.
  4. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    I'm positive that the car is off. I live in South Florida and it gets hot. I don't use the fan thing to cool the car because I thought it was running down the battery. I see by the previous posts that is not the case.
    I get to school around 7am and leave around 4pm. I'll park it with the battery almost fully charged. (I have never really seen it all the way to the top) WHen I get in at 4 it is down to about 2 bars. This doesn't happen all the time but most of the time.
    I love the car and the milage I get with it. (about 50 MPG) I know the battery and stuff is guaranteed for 8 years. I'll take a photo of B4 and after so you can see what I'm talking about.
  5. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    Photos won't help - we believe you. Get thee to a different dealer, pronto! Something is draining the HV battery while the car is off. This is not normal or good.
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Are you sure EVERYTHING is turned off when parked?
  7. TonyK51
    TonyK51 Junior Member
    44
    East Tennessee, USA
    My new 2011, which is not even a month old, has done this a time or two, and yes, I am almost 100% sure everything is off.
  8. richard schumacher
    7,683
    1,066
    United States
    The only way to be certain is to lock it; if anything is ajar or certain lights left on it will complain. Do you always lock it?
    This can be surprisingly easy to overlook. Twice now, locking mine has saved me from a drained battery in my garage.
  9. qbee42
    18,058
    3,081
    Northern Michigan
    It's not unusual for the SOC to change from one use to another. The SOC reading is just an estimate of the charge remaining in the HV battery. The computer calculates a best guess based on a number of external factors, since there isn't any way to actually look at the charge in the battery. This means that the estimate will vary a bit from time to time. Temperature can make a big difference.
    What you want to watch for is a pattern. If the SOC consistently drops you might have a problem. Likewise watch for erratic swings in SOC while driving. Failing HV batteries will often swing back and forth rapidly from full to empty, even when driving at a constant speed on a flat road.
    Tom
  10. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    Now I don't feel like I'm the only one. Thanks.
  11. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    The solar roof panel doesn't charge your hybrid battery, it's only used to run a small fan for the interior. (Hence, the packages name. Solar powered ventilation system.) The fan isn't hooked to the battery at all, it's powered by the sun only, so there's no need to worry about that.
    As for your battery draining, I'm sure you push the power button before you get out of the car to turn the system off. Correct? The Prius' SOC is comfortable at around 6 bars, that's where you'll see it most of the time. If you leave your car with 6 bars on the battery SOC (state of charge) indicator, and come back with only 2 bars, that's not normal.
    Since you have the solar roof ventilation system, that means you also have the A/C button on your keyless remote. Do you ever press that button? That could drain your battery for running the electric A/C.
    I think you should really read more about your car, or tell your dealer that their full of crap. The solar panels don't charge the hybrid battery, their not even connected. Plus, don't worry about using the fan when shutting the car off. It's powered *only* by the solar panels.
  12. bisco
    52,841
    is it working okay now? good!
  13. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Not normal but also unlikely it's really doing this that often. I'd recommend you start recording the time you turn it off and on and the bar difference. That's the only way to quantify this. You can then bring that to Toyota if you need to. 1 bar shy of top should not drop to 2 in the period of a day, it should take way way longer than that.
  14. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    Great idea. That's what i will start doing. It goes in for the 10k service in a few weeks and I'll have enough history by then.
  15. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I have a guess.... When you get to school do you do some driving on the battery alone the last part of ypour drive? Maybe a 1/4 or 1/2 mile of parking lot school road driving maybe with the ac on?
    I have noticed if I only use the HV battery on the last part of my trip the meter is slow to show it getting low, then I turn it off. Next time I start it up the guage shows 2-3 bars left and I know thats right because I used it up driving around getting my mail and driving through the parking lot without using the ICE.
    plus there is no way the battery is fully charged when you park it, Do you mean 1-3 bars from the top? The only way to top it off is a very long downhill drive like decending a mountain.
  16. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    How do you guys remember how many bars your battery had throughout the day?
  17. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Kd7,
    Remember, the Prius runs in a what we call on here stage 1 of the warmup cycle for the first minute after made ready.
    In this mode, the engine runs, but it provides little to none of the motive torque. The hybrid battery is providing this torque. If you have only moderate accelleration, or uphill travel in that first minute, the hybrid battery will quickly change its state of charge downward during this first minute.
    To be sure you are getting such a large change in the hybrid battery state of charge, you need to observe the state of charge the instant you turn the car back on, and compare it with the state of charge the instant you turned it off. If you wait even 15 seconds, while your rolling along to observe the state of charge, it could change a bar in that time, 2 or 3 bars by the end of the minute.
    Its my experience one bar change in SOC is normal stop to start. Which means 3 or 4 bars drop stop to the end of the one-minute stage 1.
  18. adamace1
    1,403
    193
    Charlotte, NC
    I just use my brian to "remember".
  19. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    Off topic but what kind of driving are you doing if you've already put 24 fuel-ups on your Prius since January of this year?
  20. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    Did we ever find out if this was the issue?
