Hybrid battery looses charge.
Discussion in 'Gen 3 Prius Technical Discussion' started by katiesdad7, Apr 13, 2011.
  1. bisco
    52,927
    i caught my neighbor hooking up wires to my pri and running his lites all nite and disconnecting everything in the morning. set up a vidcam, you'd be surprised what goes on while you're sleeping!
    PriusGuy32 likes this.
  2. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    Is this Brian guy a relative or a man-servant? Do you have him write it down or does he have a good memory:? :p
  3. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    You are right. I golf cart mode in the parking lot. Maybe that is the problem. :)
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Yes I'm right. LOL
  5. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    Well I guess that was the problem. (me) Since you told me that I have not seen it go down when I DONT golf cart it before shutting it off.
    Thanks. :)
  6. adamace1
    1,403
    193
    Charlotte, NC
    No problem, it's nice to be usefull.
  7. jamesa53
    jamesa53 New Member
    74
    Indiana
    Interesting term. Im assuming that this is the EV mode. However it should be noted that some golf carts run on gasoline engines.
  8. OZ132
    OZ132 Member
    170
    Northern Indiana
    So, then, that's the end of it?
  9. Steinmetz
    Steinmetz Good Steward
    Kalifornia
    I EV the last couple of miles to my house. Never had this happen. Smells fishy.
  10. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Unless your house is at the bottom of a 2 mile hill, or you have a plugin battery pack, you DO NOT ev the last couple of miles to your house. It's simply not possible.
  11. Steinmetz
    Kalifornia
    Oops, wrong term. The car runs in on battery power with the ICE at 0 RPMs. The ICE only runs for about 10 seconds while I climb the hill. The charge indicator rarely looses a bar and remains at the same level the next morning.
  12. Flaninacupboard
    1,297
    213
    Midlands - UK
    Again, unless you are going downhill it's not possible to drive 2 miles with the car in EV/stealth/battery only (or whatever you want to call it) mode. There simply isn't enough battery apacaity available to do it.
  13. Steinmetz
    Kalifornia
    Yep, you are correct. Seems like two miles but it's not. 0.4 miles coast from 55 mph to 20, around the corner and through the residential area, 0.7 miles. Then 0.1 miles up the hill with ICE and 0.1+ miles to the house with no ICE. Start out with -1 bar and end up with -2 bars in my driveway. No loss of juice in the morning. Been doing this every day for the last couple of months since I picked up the car.
  14. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    I've done about 1-1.2 miles slightest bit uphill at the end of a trip on EV at relatively slow speeds, without best SOC beforehand either. It could be done over 2 miles.
    Is it advisable, practical, or safe are other questions altogether. :D
  15. Steinmetz
    Kalifornia
    Please bear in mind, I am just driving the car without pushing it. There is no conscious effort to keep the ICE from starting up. It's the way the car was designed to work.
  16. adamace1
    1,403
    193
    Charlotte, NC
    Well thats different than driving a half mile on flat ground then shutting it off. Thats where you start seeing the bars drop overnight.
  17. adamace1
    1,403
    193
    Charlotte, NC
    I was on a jobsite, highway 16 it is not open to traffic yet but was paved and it is hilly. i went 2.4 miles on battery power alone i went up the hills about 7mph and down them about 15mph. and did around 10mph on the flat sections.
