Hybrid Battery Not Charging
Discussion in 'Gen 2 Prius Main Forum' started by Dvizzy, Dec 7, 2021.
Tags:
  1. Dvizzy
    Dvizzy Junior Member
    46
    Alabama
    Four Touring
    2/12/22 Update
    You made me doubt what I remembered so I went to test the cylinder compression pressure again. I got 125 psi and some change for all the cylinders. Phewfff!!!
    - I removed the fuel pump and put an external fuel source with solid 50 psi coming from an external compressor. Powered on the car and still no engine start.
    - At this point, engine timing is good, fuel is good, air sensors are good. Throttle body is good. Cam and Camshaft sensors are good.
    - Only thing left is exhaust... I removed the catalytic converter from the exhaust manifold and voila! Engine starts and runs smooth without any issues.
    That was a long and arduous process... but thanks to all of you for your help.
    Cheers!
    audiodave and SFO like this.
  2. ChapmanF
    19,050
    I'm guessing that's loud.
  3. Dvizzy
    46
    Alabama
    Four Touring
    never heard a more beautiful sound!
    SFO likes this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Jebus...how many miles does this mutt have on it anyway?
  5. Dvizzy
    46
    Alabama
    Four Touring
    350k ish and just put a 130k engine on it. 2nd hybrid battery. New exhaust. That’s nothing. I just saw a 2011 Prius c with 400k.
    audiodave likes this.
  6. audiodave
    audiodave Active Member
    800
    272
    US
    Clogged up cat caused all that?
    Sell that old cat, easy $1,000 +
