Hybrid battery overheating
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fakhar87, Jul 2, 2020.
  1. Fakhar87
    Fakhar87 Junior Member
    28
    Pakistan
    Four Touring
    Today i checked for the first time temperature of my battery by force charging it to 70%. Strange thing i noticed temp of the battery pack goes on increasing which was 45 degree centi maximum i have seen to 55 and going until i switched off the car. Does it means that battery fan is dirty because i have not serviced the fan since i bought in july2019 and dont know whnlen the previous owner has serviced it.
    52,875
    what are toyotas temp spec parameters?
    Fakhar87 likes this.
  3. Fakhar87
    28
    Pakistan
    Four Touring
    Thats what i want to ask. I have seen in this forum its 55 but when it reaches 59 the sound of fan increases- the one that cools the battery
    52,875
    that's normal behavior, and why they have a multi speed fan. but idk the correct temps
  5. Fakhar87
    28
    Pakistan
    Four Touring
    I have noticed for the first time. When temp decreases to 58 it again slows down or probably shutdown but on careful hearing you can heard little humming but above 59 it sounds like ac blower. Yeah but 70 percent battery depleted to 25 percent and engine kicks on. just in 1 mint upon starting ac. So it should be a problem of battery? Or a clogged fan?
  6. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Just clean the HV battery fan, then you will know if the rise in temperature is related to the HV battery fan being dirty (y)
    Best to error on the side of the HV battery being a problem, and plan for that future accordingly.
    Wouldn't switching off the car also turn off the HV battery fan which was cooling down the HV battery?
    Do you run the AC when using the car?
    Genevos and ydpplqbd like this.
  7. Fakhar87
    28
    Pakistan
    Four Touring
    Yeah i have noticed that too that switching off the car will turn offf the fan snd temp will increase so i started the car again and as expected from 55 to 59 and increasing then i turned on the ac snd when battery depleted and temp drops to 58 i turned off the ac. As per my experience battery with 70 percent charge produces more heat than battery with 40 percent and on 40 percent i turned off the car.
  8. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Clean the HV battery fan.
    Use the AC whenever the outside temperature is over 27C (80F), this will keep the battery cooler.
    If the HV battery SOC is moving up and down rapidly, and hasn't thrown a code (DTC), you can try to recondition it, or plan otherwise.
    Genevos likes this.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    What do you have going on with the car that you need to force charge it to 70%? Is it not staying charged?
  10. Fakhar87
    28
    Pakistan
    Four Touring
    Yeah it charges to 3 bars and again purple thats why i want to check it
  11. JerryScript
    JerryScript Junior Member
    43
    38
    We need to know the driving conditions when it charges to 3 bars then back to purple. Short trips low speed, sorry trips high speeds, as on or off.
    High battery temps can be a sign of a failing battery, but it can also be the result of high cabin air temp, especially in hot environments like deserts.
  12. lpf
    lpf Member
    139
    39
    Greece
    I suggest that you can use A/C to keep the cabin cool. Obviously, 30C air in the cabin can help to cool down a 50C battery. See attached picture. At 20:03:00 I powered the A/C at max (check showed 52C battery temp). In a few minutes temperature dropped 10 degrees with the use of fan, also, at max speed. See picture below. I'm using an app called Prius Assistant for this.
  13. Genevos
    Genevos New Member
    Do you use Torque Pro? And will setting the battery fan to high speed for better cooling be possible only when the app is running from OBD2 (similarly to Dr Prius app override battery temperature feature)? Thanks
  14. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    I've used torque, not sure if it was pro or not. Yes, you can only override the fan via an app. Is your OBD2 port currently being used?
  15. Mendel Leisk
    42,361
    Toyota set certain fan speeds for certain temps. Is it presumptive to assume lower thresholds for the various fan speeds, or just running it full blast all the time, is better? I'm not trying to be a smart-a$$, just wondering.
  16. Genevos
    Genevos New Member
    I just noticed that when I override the temperature with Dr Prius app and the fan started running in full speed the the battery temperature started dropping fast. Still not sure why my reconditioned battery heats up fast in cool outside temperature, my guess the cause is battery modules variation in capacity and internal resistance after reconditioning...
  17. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Pretty sure I read that the battery will last longer if used or stored at temps around 80F, so that is what I try to do. At max fan speed, and with the AC on, it is hard to keep the HV battery under 90F when driving around. But when parked and using the HV fan on high with or without the AC, it can cool down the HV battery in minutes (assuming ambient is under 80F). The sensors are external, so the internal is likely higher.
    Compared to the HV battery, I find it easier and less expensive to clean (or replace) the HV fan.
  18. Mendel Leisk
    42,361
    Driving on a coolish evening, around 80 kmh (50 mph), car fully warmed up, no intervention with fan speed, I recall Scangauge II showing me 35C (95F). IIRC, fan speed was 2, or 1, no higher.
    I took that to be Toyota engineers’ “status quo” temp, not sure if that’s a leap of faith though.
    Maybe involves some compromise, and who knows how optimum that is. I would think they’re conservative though, would err towards battery conservation, if the price is trivial.
    I’m debating myself now, lol.
    SFO likes this.
