Hybrid battery question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LiaLady16, Dec 24, 2016.
  1. LiaLady16
    LiaLady16 New Member
    US
    Hi again!
    Lately, during regular driving, I've been seeing 7 green bars rather than the usual 6 gray ones. Maybe I don't need to be worried, but I keep wondering if my battery needs balancing or something. Perhaps one of the cells is losing capacity and makes the computer think the state of charge is higher than normal?
    Anyways, I've been getting good performance from it, so my situation is not yet dire! Just fishing for ideas :)
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You do not give adequate information in your profile to know where you live, but much of the US has been cold lately, so Prius in those cold areas run the engine just to keep the cabin warm. One side effect of running the engine more is more electrical charge.
  3. LiaLady16
    US
    Ah, that makes sense! This is my first winter with my car. I live in the DC area, so it hasn't been very cold, but I suppose it could be chilly enough. I don't really use the heat, but the car might need to keep the cat warm for emissions?
    52,641
    balancing is an excellent idea. see @jeff652
    WilDavis likes this.
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Not really.
    Unless there is hard evidence that it NEEDS to be done, as evidenced by something more than a small subtle change in a display, it probably should NOT be attempted.
    If it ain't broke, don't fix it !!!!
  6. bisco
    52,641
    you're probably right, i'm just repeating what i've read here. there's likely no value in rebalancing the cells in older batteries.
  7. LiaLady16
    US
    Alright! I can wait until it starts dragging its feet, if you will. I was more worried about it because right now I'm driving at least 2500 miles per month, and was considering some preventive battery maintenance.
  8. bisco
    52,641
    word on the street has it that battery maintenance only works when the battery is working, not after it dies.
    Raytheeagle and WilDavis like this.
  9. LiaLady16
    US
    I've read that too, on the prolong battery charger site. I'll probably go for a charger soon, for maintenance purposes and maybe a little more highway passing power! I'd like to keep it for another 80k at least. And I've seen that some on the forum have over 300k!
    jeff652 likes this.
  10. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    If you start seeing rapid and wide swings in the charge, coupled with the cooling fan running (vent in the rear seat), it's time to start worrying.
    There may be some value to a high voltage charger, but I think they're an expensive tool for maintaining a single car. Personally I'm putting that money into my battery replacement fund. I've noticed the Prius does a pretty good job of maintaining its battery under many driving conditions (see this report). And if a module fails electrically or mechanically, which they do, discharging and recharging it is not going to fix it.
  11. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    So you seem to be suggesting that you only need to get insurance just prior to having an accident! o_O Please explain your logic to this ignoramus as to how you get the timing right… :confused: ;)
  12. Sam Spade
    2,036
    1,024
    2017 Prius c
    OK, let's put it a different way:
    Most average users shouldn't worry about it.
    Because to KNOW when and if it needs to be done requires some testing.....and to be sure, testing individual cells.
    There is some danger involved in that. Many owners don't have the skill required.
    And I personally have some doubt that it really does any significant good anyway.
    Just my opinion, mind you.
  13. WilDavis
    2,493
    2,155
    49
    Ok, so I realize this is an oldie, but how much more appropriate for me to reply with another "oldie":
    "Allow me to remind you of the following:
    1) If it ain't broke, don't fix it!
    2) If it ain't broke, fix it until it is broke! [​IMG]
    …and let us not forget the Software Engineering Rider:
    2a) If it ain't broke, it doesn't have enough features!" ;)[​IMG]
