Hybrid Battery Question
Discussion in 'Gen 3 Prius Main Forum' started by kamrul, Oct 10, 2025.
  1. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    I am saying that the Delta SOC is just as important as the voltage difference. A hybrid battery with a 42.50% Delta SOC is NOT a healthy battery pack. You do not even need to look at the voltage difference reading when the Delta SOC is 42.50% to know that the battery has a problem.
    Please explain to the OP how you would fix a hybrid battery pack that has a 42.50% Delta SOC.
    #21 Brian1954, Oct 11, 2025
  2. Brian1954
    2,694
    1,077
    Would you also question why the 12v battery reading of 14.2v does not change during the 3 minute video?
    #22 Brian1954, Oct 11, 2025
  3. Brian1954
    2,694
    1,077
    I just noticed your post. The voltage difference in the video is so low because the current usage (charging or discharging) is very low. If the current usage was higher (like 50 to 80 amps), the voltage difference readings would be much higher. The OP is getting a large enough voltage difference between the battery blocks to activate the P0A80 code when he is driving the car. If the OP has a scanner capable of reading freeze frame data, he could look at that freeze frame data and see the voltage level of all 14 battery blocks when the code was triggered.
    davecook89t likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
    First thing I would do is tell them to monitor voltage difference in real time under hard braking and hard acceleration to get a better sense of severity of the problem and how much time they have left on the pack. Then I would find out their skill level and what they can afford and then I'd give them a range of options to make repairs in their price range.
  5. Tombukt2
    Tombukt2 Senior Member
    13,871
    2,521
    Durham NC
    Well I've got 1 car that most of the rear trims pretty much stay out of car . Then I wind up cleaning and vacuuming garbage out of the area and stuff like that . I've never seen a cat clean enough to just drop battery in and let it go.prius folk down souf tend to be like horse and cat and dog folks so hay and hair in full effect. My personal cars have to be washed back they're when I get em
  6. Brian1954
    2,694
    1,077
    Thank you for your reply to my question.
    I provided my recommendations in post #7 for fixing the hybrid battery.
  7. PriusCamper
    13,472
    5,439
    Yeah... Same... Only time I've got near that 45 minute record is when problems are happening with a car I've already got cleaned up and usually I'm mad about having to swap a pack and friends or customer knows its not a good time to ask any more questions so everything goes very quickly... And as I'm sure you're also aware, if ya start talking to people too much while working mistakes happen.
  8. Tombukt2
    13,871
    2,521
    Durham NC
    Usually there's no one here to talk to
    PriusCamper likes this.
  9. PriusCamper
    13,472
    5,439
    I guess that's why you talk on here so often?
