Hybrid Battery Re-balancing - How important is SOC?
Discussion in 'Gen 2 Prius Technical Discussion' started by Jimmy Lam, May 22, 2020.
  1. Jimmy Lam
    Jimmy Lam New Member
    Hey guys,
    So i'm just in the final stretch (hopefully) of repairing my hybrid battery. HUGE thanks to everyone on this forum for all the knowledge and help!
    I've already load tested, replaced the bad modules. and cycled all the batteries, and am in the process of balancing the pack. From what I gather, I should match the blocks according to capacity. I then need to connect the modules in parallel for a day to equalize the voltages before putting the pack back into the car.
    HOWEVER, do I need to make sure that the modules are all in the same state of charge before reinstalling? They're all currently fully charged. If so, what would be the best way to do this? (I've thought about individually discharging and charging each module up to say 4000mAH but this seems tedious).
    Any help would be so greatly appreciated!
  2. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    This procedure has fallen out of favor as it doesn't really accomplish anything, so save yourself some time and skip it.
    Discharge them down to the same voltage. 7.8/7.9 V is a good target. As long as all the modules are 0.1-0.2 V of each other the BMU won't be too worried.
