Hybrid Battery Reconditioned Reset Problems??
Discussion in 'Gen 2 Prius Technical Discussion' started by Four1Seven, Oct 13, 2020.
  1. Four1Seven
    Four1Seven Junior Member
    Springfield MO
    Hello all,
    I just reconditioned my whole pack, replaced 10 modules, and used the Prolong Charger and discharger. Put the pack back in and it shows good voltage and drives but all the lights are still on. I reset them and it will drive normal for 5 minutes then all the lights will come back on. If I leave them on and drive about 10 minutes the engine will change revs and stay higher revved and there is no power. I don’t know if this is still a problem with the pack or if I just need to reset something to recalibrate the system? I disconnected the ground on the 12v battery and left it overnight while I charged the hybrid pack with the Prolong Charger. The next day drive it and still have the same problems. Once again I’ll reset the engine codes while driving and it will drive normal but 3-5 minutes later the lights come back on. This is my first time trying to recondition the pack so I’m clueless. This is on a 2007 with 170,xxx miles. Please any help would be greatly appreciated.
    Thank you all,
    Ty
    C Wagner likes this.
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Sounds like there are still battery issues being noticed and reported. Reading the codes would be the first step. Many issues are due to workmanship: improper torque, unconnected or misconnected wiring/connectors, misdiagnosed modules, poor replacements, etc.
    GOOD LUCK!
    C Wagner and Four1Seven like this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,110
    2,011
    NJ-USA
    +1 to fotomoto
    If the car is turning on indicator lights then you need to read what codes are set- particularly any sub-codes.
    If you think that there is a problem with the HV battery voltages then you need to log the block voltages with either a techstream scantool or use a compatible bluetooth scan adapter with an app like Dr. Prius or Hybrid Assistant. You need to see what the voltages are when the pack is under heavy discharge and charge conditions. You may need to clear codes once in the battery ecu after completing work- if it resets the warning lights then something is still wrong.
    When you worked on your HV battery, did you: clean or replace the bus bars? inspect the voltage sense wires for corrosion or damage? use a torque wrench to tighten the bus bar nuts to spec? inspect the battery ecu connections for corrosion?
  4. Four1Seven
    Springfield MO
    C2EB6C32-1DE3-4674-98A4-074B11C43467.jpeg I have read the numbers with Dr Prius and it seems block 14 is low. That’s the code it says also. How do I clear the codes for the battery ECU? Is that the same as just clearing the codes with a scan tool like the check engine?
    I did clean the bus bars with a brush. They turned a copper like color. I was worried about corrosion so I put bulb grease on them when putting them back. I didn’t use a torque wrench when putting them back on. Wasn’t aware they needed to be torqued to a certain spec. What do you recommend I do? Here is a picture of what the bus bars looked like after cleaning. C2EB6C32-1DE3-4674-98A4-074B11C43467.jpeg
  5. strawbrad
    953
    1,007
    Try reading the codes with the Torque app. It could pick up codes that Dr Prius is missing. Toyota Techstream will read all the codes.
  6. mr_guy_mann
    4,110
    2,011
    NJ-USA
    Those bus bars don't look too bad. The nuts that hold them to the battery studs should be tightened to 48 INCH-pounds. If they are too loose (or corroded) , you can get false weak block codes. If you go too tight you can damage or break the stud. Buy or borrow the correct torque wrench.
    So what was the code ? and how low was the block voltage compared to the others, under what discharge amps, and what does that same block do when charging/ regen?
    As far as clearing the battery ecu codes I believe that it is an option in the Special Features menu on Dr Prius.
    #6 mr_guy_mann, Oct 14, 2020
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    It sounds like you have found your answer. The part that stinks is that block 14 is the one closest to the ecua and requires the most disassembly to get to.
    But....definitely make sure it isn't a wire/sensor/connection/plug/socket issue before you go through the hassles of disassembly.
  8. dolj
    dolj Senior Member
    8,634
    4,388
    Wellington, New Zealand
    I hope you put the grease on after assembly and not before. Any anti-oxidation measures should be applied (lightly with a brush) after assembly so you don't introduce insulation to where it is not needed.
  9. C Wagner
    C Wagner Member
    183
    60
    Boston
