Hybrid battery reconditioning help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Stefanovich, Jun 23, 2023.
  1. Stefanovich
    Stefanovich Junior Member
    47
    24
    Portland, OR
    I took my Gen 2 2006 Prius on a 500 mile round trip a few days back, and I noticed I was only averaging 42 MPG at 75 mph. Decided it was time to check the Dr. Prius app and the results were alarming. The internal resistance of all the cells were at least 31 milli ohms, with the highest being 35-36 milli-ohms. This is worryingly high for a traction battery that is only 3 years old. It looks like I will need to recondition the battery.
    So... Does anyone by chance live in or near the Portland, OR area that would be willing to let me rent their Prolong system? It would beat paying $700 for a new one. Or maybe help me with a block charger. Whatever helps.
    I got the replacement through newpriusbatteries if anyone is wondering. Maybe I should have stuck with OEM, but I'm here now.
  2. PriusCamper
    PriusCamper Senior Member
    13,428
    5,421
    Pacific Northwest, USA
    I'm less than two hours North of Portland and could retrieve my Prolong that I loaned out to loan to you? Or you could borrow/buy the one @fach built here: Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
    Stefanovich likes this.
  3. JC91006
    16,936
    8,647
    This battery that was sold was never really tested for long periods, just got on the market and everyone decided to jump on the bandwagon and say how good this product is compared to OEM. I guess everyone is learning how awful these things really are after 3 years.
    I'm not even sure if the prolong system will do anything to help these inferior battery packs, but you can certainly try and post your results.
  4. Stefanovich
    47
    24
    Portland, OR
    Buyer beware, I suppose. Still, a lot of people here were reporting positive results so I thought it would be safe. It sounds like I would have had just as much luck with Green Bean or some other aftermarket reconditioner. And at the time OEM batteries were very expensive. I guess there's a reason the warranty was only for 2 years. Well, if the reconditioning doesn't work then I might just move on to a newer car when my battery eventually fails. My 2006 is a bit long in the tooth anyway.
  5. bisco
    52,807
    most people here are having good success, but there have been a couple failures.
    have you reached out to newpriusbatteries?
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    And the glowing reports about how great the "reconditioning" process is seem to be fading away too.
    I wonder why ?
    No, that's a lie, I KNOW why.
  7. Stefanovich
    47
    24
    Portland, OR
    Honestly I didn't really see the point. I am past the warranty for the batteries. I suppose I could try and see if @2k1Toaster can help. They are the person behind New Prius Batteries iirc.
  8. bisco
    52,807
    even out of warranty, he might sell you a module or two
  9. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    The epa rating for highway is 45 mpg, so for a 17 year old car I’d say your 42 mpg is pretty good for interstate speeds. Overall the battery doesn’t look bad. I mean the resistance isn’t great but how can we conclude this battery is failing and needs to be reconditioned?
  10. Stefanovich
    47
    24
    Portland, OR
    Personal experience. I have made the same trip not terribly long ago and I got much better MPG. That's why I checked the Hybrid battery in the first place. Because I have done better. Unless I got really bad luck and was going into a headwind most of the trip, which is exceedingly unlikely period
  11. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    The difference between the highest and lowest block is a very minimal 0.07 V so I don't think you've got anything about which to worry. The way the Dr. Prius app graphs the voltages exaggerates the height of the bars so it looks bad, but if it was graphed properly all the bars would be virtually level.
    audiodave likes this.
  12. PriusCamper
    13,428
    5,421
    The number above that one that measures amps going into or out of the pack is below 2amp in the screenshot. Even a failed battery pack can look that good when there's hardly any amps going on. But a hard breaking or hard acceleration getting those amps up to 50 or so will send that voltage difference number soaring on an ailing pack.
    Stefanovich and Brian1954 like this.
  13. Noahdoge
    219
    148
    Mississippi
    @PriusCamper Agreed. That’s why it’s best to screen record and go out on a 10 minute drive to get more accurate readings.
    Here’s a recent drive I did. 2012 original battery.
  14. dolj
    dolj Senior Member
    8,635
    4,389
    +1 @PriusCamper, easily overlooked, but more telling than a static snapshot.
  15. Stefanovich
    47
    24
    Portland, OR
    Yeah, it looks pretty bad in motion. I'm not sure how to attach a screen record to my post but I was monitoring it while driving and it looks worse than my screenshot presents it.
