Hybrid Battery Replacement code P0A80 abnormal behaviour
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Randell, Sep 22, 2018.
Tags:
  1. Randell
    Randell New Member
    Trinidad
    I have a 3rd generation 2014 Toyota Prius and every so often the code P0A80 Hybrid Battery Replacement code keeps popping up ever so often! I have a obd2 scan tool so i reset the fault code in order for the hybrid system to function! when i perform a reset, it could be weeks till the fault code comes back up again, or it could be days! Time varies!
    So I decided to scarp the hybrid battery and perform some checks on the cells! Every cell i got between 8.02 to 8.05 volts! so seemed like they were all good! then i decided to clean the links that connected the cells together and shine them up good! I also cleaned out the cooling fan for the battery!
    Mounted everything up and started my car and everything was good for a while, but then it still keeps coming up!
    Need help! anyone at all have suggestions based on this experience! would really appreciate some help!
  2. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Not sure about where you are , but a 2014 should have been in warranty for anything hybrid related upto 100K miles or more.
    I think the android app torque pro with optional PIDs loaded for the prius will show more info on the HV battery for you.
    How is your 12v battery?
    49,498
    how many miles/km on her? you have to test the cells under load with tech stream while driving.
