Hybrid Battery Replacement Reset
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Joe Gregory, Feb 3, 2024.
  1. Joe Gregory
    Joe Gregory New Member
    2014 Prius c
    I have replaced the hybrid battery after the dreaded P0a80 code. I have replaced it and installed it and am still getting the same check hybrid system message. Do I need to reset the battery or something? I can’t wrap my head around why I still get the code.
    igorprius777 likes this.
    49,388
  3. PriusCamper
    PriusCamper Senior Member
    11,063
    4,504
    Pacific Northwest, USA
    It takes as long as 600 miles of driving to finally clear... Happens on Gen3 more often than on Gen2. As long as the yellow triangle and other warning lights are not lit up and car is running normally you have nothing to worry about.
  4. ChapmanF
    15,468
    Does this mean you for sure have the P0A80 code again, or just that you have the "same check hybrid system message" again? There are around 200 different codes that can give you that message, so just saying it's the same message isn't saying much; need to know what the codes are now.
    Brian1954 likes this.
  5. Joe Gregory
    2014 Prius c
    I am now getting the following codes: P0B6F and C1310
  6. ChapmanF
    15,468
    The C1310 is just there because of the P0B6F. P0B6F is a "low" voltage reading on on circuit "K" (the eleventh one) monitoring the battery block voltages. When they say "low" for this code, they mean really low, like less than 2.5 V, not any realistic reading for a block, so it's likely to mean a connection or wiring problem.
