Hybrid Battery Replacement???
Discussion in 'Gen 3 Prius Main Forum' started by Gregory Baird, May 8, 2019.
  1. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Hmm. Going from NIMH to Lithium. That's a whole different battery chemistry, and they aren't charged in the same way. Is it even possible to change the way a Prius' charges the battery?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Glad you resolved the battery issue. But I'm 99.99999% sure that is not a lithium battery. The performance improvement would be negligible and the effort would be tremendous if it can even be done. And there is nothing on the website bragging about it being lithium. They would make a big deal out of that since I'm not aware of it being done before.
    On the misfires. If it's alway the same cylinder, try swapping that coil with one in another cylinder to see if the misfire follows the coil. If it stays on the same cylinder, I might suspect a head gasket leak, especially since you say it does it more going up hill or with a car full of passengers.
    Fostel likes this.
  3. Prodigyplace
    12,720
    11,852
    Central Virginia
    They are bragging about increased capacity though. Lithium would be one way they could do that.
  4. jerrymildred
    11,517
    14,171
    Tampa, FL
    So would new cells. And some businesses just say that with no basis at all. <need head scratching emoji>
    Raytheeagle likes this.
  5. Prodigyplace
    12,720
    11,852
    Central Virginia
    jerrymildred likes this.
  6. topshot
    topshot Member
    154
    58
    Midwest
    2015 Prius c
    Which cylinders? You seem to have thrown a bunch of money at replacing things without doing any diagnostics.
    Fostel likes this.
  7. bisco
    52,896
    (n)
    jerrymildred and Grit like this.
  8. bisco
    52,896
    i don't see anything in your earlier posts about misfiring.
    you replaced a lot of stuff after complaining about a weak hybrid battery and poor mpg.
    and you completely misinterpreted the 12 volt advice.
    i guess coils and head gasket are about all that's left of the old car
    Fostel and jerrymildred like this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I use the whistling emoji for those cases in it’s absense(y).
    #29 Raytheeagle, Aug 3, 2019
  10. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    For jerrymildred, a nice big one ;):
  11. jerrymildred
    11,517
    14,171
    Tampa, FL
    I love it!!! Thanks. I downloaded it and will probably use it a lot if that's OK with you. :D
