Hybrid battery sensor
Discussion in 'Prius v Main Forum' started by Anthony Maita, Sep 21, 2022.
  1. Anthony Maita
    Anthony Maita New Member
    Not really sure what to do any suggestions
  2. Air_Boss
    Air_Boss Senior Member
    4,231
    1,190
    New Yawk
    For starters, check and if needed, clean the battery fan.
    Anthony Maita likes this.
  3. Anthony Maita
    Thanks I will try that.
    52,562
    any trouble lights?
    what code reader?
    are you losing any coolant?
  5. ChapmanF
    18,757
    Because Toyota uses negative-temperature-coefficient thermistors for these temperature sensors, when you see a trouble code about a "temperature sensor circuit high", that means the ECU is getting some incredibly low temperature reading from that sensor—as would happen if the wiring to that sensor had a break, or a bad, high-resistance connection, or was somehow shorted to a circuit with battery + voltage. So it isn't about a high temperature reading, but quite the opposite. A cooling fan issue would not give you this code.
    The sensor this code is talking about is the single thermistor that is clipped to the hold-down bracket of the 12 volt battery in the corner of the hatch area. The cooling fan (for the traction battery) doesn't have a lot of effect on that 12 volt battery anyway.
    The usual way to proceed would be by making the connection and resistance tests shown in the repair manual for that code.
    Toyota Service Information and Where To Find It | PriusChat
  6. Anthony Maita
    Ok makes sense I had a subwoofer installed so maybe when that was installed something wasn't put back right
  7. Anthony Maita
    No trouble lights surprisingly
    Carista OBD2 Bluetooth reader is the reader I'm using
    And no I don't see any coolant leaking
