Hybrid Battery Survey-Gen2 Prius 2004-2009
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wjtracy, Sep 18, 2013.
  1. Failed below 100,000 miles
    6 vote(s)
    4.8%
  2. Failed between 100,000 and 150,000 miles
    8 vote(s)
    6.3%
  3. Failed between 150,000 and 200,000 miles
    5 vote(s)
    4.0%
  4. Failed at over 200,000 miles
    1 vote(s)
    0.8%
  5. Has not failed below 100,000 miles
    42 vote(s)
    33.3%
  6. Has not failed between 100,000 and 150,000 miles
    37 vote(s)
    29.4%
  7. Has not failed between 150,000 and 200,000 miles
    19 vote(s)
    15.1%
  8. Has not failed at over 200,000 miles
    8 vote(s)
    6.3%
  1. Jolly
    Jolly Junior Member
    81
    Appleton, Minnesota
    New 2009 Prius owner here. I was wondering if it's hard on the battery (if it's showing purple or very little charge) overnight when it drops to -10f to -30f during the night. Should I try to get a fuller charge on the battery by leaving the car run for a bit when I get home from work? Seems like a waste of gas but if it helps towards battery life I would do it.
    Jolly
  2. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi Jolly. Yes I believe in at least trying to limit the number of larger SOC swings where possible. I mean some large swings are going to be unavoidable, but limiting them where possible is probably going to help with an aging battery.
    What are the circumstances which causes it to drop to low (purple) SOC in the first place? I find the best option is to try to address this aspect of the problem.
  3. Jolly
    Jolly Junior Member
    81
    Appleton, Minnesota
    I suppose it's because I drive the last mile on my way home in EV only.
  4. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    well, there's another PriusChat member who also does that and he is over 200,000 miles on the battery, so I thought maybe he was on to something. Keep in mind the experts here say that there is rarely a need to use EV mode except the obvious case of moving the car a short distance e.g. in the driveway. Except for the rarest of circumstances, using EV mode during regular driving will slightly hurt (not help) overall MPG.
  5. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Is that EV mode via button or just by being virtue of low speed driving and a light foot? Are you in a country with EV button as standard equipment, or have you done the EV mod.
    It's pretty hard to get the SOC down to 2 bars or less on a Prius with warm engine by just being light on the accelerator pedal. o_O
  6. Jolly
    Jolly Junior Member
    81
    Appleton, Minnesota
    I have no EV mode installed. Just being light on the accelerator during my last mile home to my farm on a gravel road with NO traffic at all! I suppose I could just continue to PnG . I've improved my MPG to 58 since joining this site. My commute to work (in rural Minnesota) is 6 miles. Got the glide part down prettty good but still confused about pulse. I've read here and on other sites to pulse "briskly" up to 41 mph and then glide. On the other hand, other comments made about pulse is to avoid using any use of the battery power to get to 41 mph. I'm finding that difficult to do if I am to accelerate "briskly". I don't understand.
  7. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    You must pulse with the ICE ON, how much it's hard to say on GEN II, because it doesn't have HSI bar.
  8. Jolly
    Jolly Junior Member
    81
    Appleton, Minnesota
    Yes, I realize that, but from what I've read one shouldn't let any battery power be used with the ICE during pulse - only ice and charging. I find that counter intuitive.
  9. Pbaker
    Pbaker Junior Member
    A guy here at work, has a 2004 and at 138,000 the traction battery failed, replaced under warranty at the dealership.
    He says the mileage has improved, and has had no other problems.
  10. ursle
    ursle Gas miser
    1,049
    192
    NH
    On the gen2 the screen that shows where energy is coming from going to,
    You want to, when coasting feather the accelerator so you don't see the screen doing anything, there's a point at which the ice is off and the screen shows no current being sent to the battery or from the battery, it's a learned habit, after watching the screen and learning when and where and how to do it, it can become 2nd nature, it happens around 30mph.
    Tru, for best overall mileage when in traffic, accelerating briskly to speed and then maintaining speed will give the best results, unless one is hyper "miling" slowly;)
  11. Jolly
    Jolly Junior Member
    81
    Appleton, Minnesota
    Yeah, I've been practicing the glide part (no arrows) and I believe I've got that part down. Should I be accelerating slowly (to get to the glide) so I don't use any battery power? Once again, when accelerating quickly, I see I'm using battery power. Driving a Prius is the most entertaining thing I've come across in my 60 years! And I've owned a LOT of cars!
    Data Daedalus likes this.
  12. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    OK thank you but you have to tell us where "here" is but we can assume it is a CARB state.
    One preliminary survey finding, of the Gen2 batteries that fail, many go between 100k and 150k. Many of those are in CARB states, so they get replaced under warranty. So it does appear the CARB 150K mile warranty is a nice thing to have in the case of Gen2. I wish we could all get 150k mles batt warranty.
  13. Jolly
    Jolly Junior Member
    81
    Appleton, Minnesota
    Sorry, newbie here. Don't know what CARB means.
  14. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    CARB stands for "California air resources board ". States that belong to this organisation get a 10 year 150,000 mile guarantee on emissions related parts. HV battery, catalytic converter, inverter,and transmission.
    John (Britprius)
  15. Jolly
    Jolly Junior Member
    81
    Appleton, Minnesota
    Thank You!
  16. Britprius
    5,194
    1,921
    It would help others to help you if you put your location in your avatar. Lots of aspects of the Prius vary with location and this information also helps us to guide you to local recommended repairers and parts supplies when required.
    John (Britprius)
    wjtracy likes this.
  17. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    good answer for further clarification I'm going to quote wikipedia
    I guess the list for pre 2011 cars is
    California, Connecticut, Maine, Maryland, Massachusetts, New Jersey, New York, Oregon, Pennsylvania, Rhode Island, Vermont, and Washington, as well as the District of Columbia
    with 2011 adding new Mexico and 2012 adding Arizona.
    When I first read it I parsed it as CA, then a list of 2012 states, then a list of 2011 states. Makes more sense to me if the other two states were added later to just put them at the end of the paragraph instead of mixed in the middle.
  18. Jolly
    Jolly Junior Member
    81
    Appleton, Minnesota
    All right! I've added data to my avatar. Please bare with me. I'm learning every day. Think I'm becoming obsessed with this quest for information. And driving a Prius!
    Data Daedalus and wjtracy like this.
  19. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    Almost -- but not exactly -- the same list as the 15 PiP (Plug-in Prius) roll-out states. I am surprised by the two new as I don't recall them being mentioned in the 2013 Hybrid warranty (Toyota nor FORD).
  20. PorcoRosso
    PorcoRosso New Member
    Bought my Prius new seven years ago and battery just failed at 96K+ miles. 5-6 of driving years done in hot AZ climate. Dealer says they are waiting for delivery of replacement battery which has to be shipped by Hazmat due to contents of battery. They have had the car since last Thursday. Hopefully I'll get it back today.
    Curious to hear what others experiences have been regarding turn around time for the battery replacement.
