Hybrid Battery Terminal Bolts
Discussion in 'Gen 3 Prius Technical Discussion' started by Borninblue, Apr 8, 2020.
  1. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    I have a two part question. Was getting ready to install Prolong charger and noticed corrosion on all the bolts. I decided to take all the bolts off and clean the bus bars as well. Of course I dropped one of the bolts on the underside of the battery and I gave up looking for it. Any clues if a hardware store would stock this bolt or does it have a special coating? Does anyone have the part number if I need a replacement? Lastly, can I soak the bolts in anything to remove the corrosion or should I just take a wire brush to them?
  2. Mendel Leisk
    42,256
    You mean nuts right?
    I read here someone dropped them in vinegar and they promptly turned black. Not sure of the ramifications of that, but maybe don't do that.
    To get a physically identical nut, take one of the remaining nuts along to a hardware store, test fit it on their metric bolts, then find a nut for sale that fits that bolt, and similar style. I think they maybe have integrated washer?
    I'd guess it's M4 coarse thread.
    Torque is roughly 48 inch pounds 4 foot pounds) IIRC.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    The nuts for the busbars are just normal M5 (x 1.5 pitch I believe).
    If you lost one screw from the bottom, which is what clamps the module to the baseplate, I wouldn't get too worried about it. The modules interlock with each other. The module on each side of it will keep it well in place.
    Be extremely careful cleaning the busbars . many people damage the fine voltage sensing wires/tabs when they try to remove the copper bars. Life is much easier if you just purchase a new 'wire frame #2' from Toyota. It's the entire voltage sensing harness with busbars and wires. Just need to reuse your heavy orange cables, unless you buy new ones of those also. I put all new harness/cables/disconnect in my batteries when I build them.
    Borninblue likes this.
  4. ASRDogman
    ASRDogman Senior Member
    8,039
    4,074
    Not sure if they are nickel plated nuts. You could check with Toyota and see if they can get one for you.
    Maybe a spare one just in case.
    You can use baking soda and water, I make a paste and us a tooth brush. That's a safe way of doing it.
    They use a wire brush or fine sandpaper to clean them up.
  5. Mendel Leisk
    42,256
  6. PriusCamper
    PriusCamper Senior Member
    13,402
    5,412
    Pacific Northwest, USA
    If it's just one nut, just go to the hardware store and replace with matching size. Nothing special about them... But ideally, to be thorough, I replace bus bars, voltage sensor terminal and nuts all at the same time. If you want to do that I can share links with you?
  7. PriusCamper
    13,402
    5,412
    Lol... Toyota would you sell you one nut? I can see the confused look on the parts guys face when he looks it up and it says you have to buy the whole pack replacement for $1700... Too funny... Most efficient way to clean bus bars is a rock tumbler...
  8. Borninblue
    233
    158
    Cleveland, Ohio
    Thank you, I would appreciate the link!
  9. Borninblue
    233
    158
    Cleveland, Ohio
    Yes sorry, I did mean nut!
  10. ASRDogman
    8,039
    4,074
    In the past, I've purchased just one nut or bolt from Toyota, and ford, and Chrysler.
    I was actually surprised, I just took a chance.
    Since I've never worked on the battery, I don't know if they are special nuts or just regular nuts.
    My impression was they were brass or copper. And/or they had a coating because the terminals are
    a different metal.
    rogerdpack likes this.
  11. ASRDogman
    8,039
    4,074
  12. Mendel Leisk
    42,256
    These guys will, $1.59 (CDN) apiece for me. No extra shipping charge since I've got a couple of air filters in the cart already.
    Genuine Toyota G9291-47011 (G929147011) - Amayama
  13. Borninblue
    233
    158
    Cleveland, Ohio
    Well I did something stupid. Some of the terminals on the modules were showing corrosion. I took a wire brush across the top and sparks, actually a small flame came up. Yes I took out the orange master clips before working on the battery. Obviously the metal touched two terminals and they are still charged....I thought now power but didn’t think you dummy modules still have power.
  14. ASRDogman
    8,039
    4,074
    Of course they have power.... each cell has power, they are linked in series.
    You should quit while you are behind, and before you cause serious damage to the battery, and YOU!
  15. hotelprisoner
    hotelprisoner Member
    104
    87
    Ontario, Canada
    Technology
    Toyota Parts like G9291-47011
    $0.70 CAD
    Took a month to arrive but I got them. They are non-standard size compared to same found at McMaster-Carr. The Toyota version has a wider base.
    iPad ?
  16. Mendel Leisk
    42,256
    McMaster Carr won't ship to individuals in Canada. THE place to window shop tho.
  17. Borninblue
    233
    158
    Cleveland, Ohio
    I took out all the bus bars and cleaned them. All I have to do is put them back in and hook up the prolong wires...Is it not safe to take out the bus bars? 12volt is disconnected and traction battery orange plug is disconnected as well. I understand what I did by trying to clean the module terminals was stupid.
  18. ASRDogman
    8,039
    4,074
    Nothing wrong with cleaning them. You just have to be careful.
    Maybe a plastic straw over the studs next to the one you are cleaning?
    Just go slow, and carefully
  19. Borninblue
    233
    158
    Cleveland, Ohio
    Thank you, just don’t want to shock myself or worse kill myself putting the bus bars back in but I’m assuming as long as I don’t become a conductor between two terminals in the process I’ll hopefully be OK. Also is there a fuse somewhere for the traction battery, I’m wondering if I might have blown something by making contact with the two terminals.
    #19 Borninblue, Apr 8, 2020
  20. Mendel Leisk
    42,256
    I think worst shock you could incur is if you put your hands one at each end terminal. Deal with one connection at a time, and think: don't provide a short circuit.
    Whenever possible, keep one hand in your pocket.
