Hybrid Battery unused for 18 months
Discussion in 'Gen 2 Prius Technical Discussion' started by CWB, Aug 13, 2023.
  1. CWB
    CWB Junior Member
    25
    Michigan
    My 07 has been sitting unused/not started since Jan 2022.
    I assume the hybrid battery is shot?
    Or advice on how to get it to work? Trickle charge or?
    Thanks
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    The hybrid battery seems to be able to withstand long periods of non-use.
    But at 16 years old, it might be shot anyway.
    Charge or replace the 12 V battery, put fresh gas in it and see what happens.
    Meg&Bear likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    13,851
    2,515
    Durham NC
    Have you gotten the 12 volt straightened out and everything's ready to go? Have you tried to start it?
  4. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Agree with Sam. Also build yourself a "grid charger". Cheap and easy.
  5. bisco
    52,832
    if it won't start, you would need a grid charger, or hobby charger for individual modules. if you go the hobby charger route, you can replace bad modules at the same time.
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    Also mostly ineffective and potentially dangerous.
    MOST people have no business messing with high voltage.......in any form.
  7. Tombukt2
    13,851
    2,515
    Durham NC
    I just started one sitting quite sometime . Walked up with a new 12V . Made sure it could ready it did. And the engine fired right up in front of the folks I just paid 700 bux cash for car . Other half drove it approx 55 miles home smoking the tires practically all the way . Not 1 issue . But 8 believe HV battery is shot like all of them .
