hybrid battery water damage
Discussion in 'Gen 3 Prius Technical Discussion' started by jaegerd, Jul 6, 2011.
  1. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    As everyone has already suggested I'd try a different dealership.
    Also, from your original statement? If you are "sure" that there was no water in the back of the car when you pulled the plastic under the plants? Then I would of admitted to nothing. None of their business that you hauled some plants from home depot. If you are being honest? And there was no water damage from this incident..then sharing with them that this happened just gives them a convienent excuse to blame you. That horse might already be out of the barn...but I would of just let them tell YOU how the battery became water damaged, and not of voluntered a scenario, especially if you did the hauling and noticed no water.
    I think I remember a thread where it was brought to everyone's attention that Toyota does recommend against hauling anything with the potential to spill. I think it was a "No Aquariums" in the back of a Prius warning....
    But ultimately? If you are saying no water damage occured? Then leave it up to the dealership and Toyota to determine what happened...
    Volunteering a "Maybe This Happened" scenario, simply becomes grounds for them to deny warranty coverage.
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    you said you have kids right?... water... vent... let's see what happens if water goes down this vent... (just sayin)
    btw.. reason C is a real problem i feel. the car will not throw codes for it till 2 cylinders stop firing... then it shuts off and requires a restart.
    if the connectors to the ignition coil(s) get unplugged, it throws codes and stops the engine.
    if a spark plug fails to fire, it will throw codes and stop the engine.
    just not the coil itself...
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  4. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Just to clarify, you are saying reason "C" from list below
    ICE common cause for hybrid battery failure
    Causes for poor performance in the ICE are varied but the usual culprits are
    a) MAF sensor
    b) Spark plugs
    c) ignition plug in coils
    d) throttle body
    e) air filter
    f) oxygen sensor
    g) engine oil and coolant
    h) Clogged catalytic converters
  5. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    Jaegerd- It seems a bit unlikely that hauling plants from Home Depot would be enough to cause water damage - even if they were wet the water would need to soak through the seats and/or carpeting - everything would likely be soaking wet.
    However this does not mean that there could not be water damage, just that if there is, the cause is likely something else. If you rule out the obvious causes such as spills and open windows I would imagine that the likely cause is a bad seal - either around the windows and doors or perhaps the back hatch. I had a VW that had an issue with the sunroof - water would appear either in the floor of the back seat or also in the well behind the rear wheel so if water gets in it can travel to all sorts of funky spots.
  6. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Enough water to damage the hybrid battery would have to leave some sort of residual evidence whether it be stained carpet in the cargo area, or stained floor boards underneath the seats. Also I would go under the car and look for evidence of water staining/rusting on other components and the frame structure itself. It should really be easy to prove water damage.
    If water really did do the damage, this may be a possible insurance claim. It's worth investigating.
    Without more dealer information, I agree that something smells. Oh by the way, do you have any musty smells in the back cargo area?
  7. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Do you track your fuel mpg? If yes, see if you have a real drop in mpg lately because leaky batteries or failing ones will cause the engine to run more to try to keep the batteries charged and this results in poor fuel enconomy.
    The fuel tracking could give you a good time line as to when something could of happened or when it started to go bad, if it was not the plants.
    The plants could just be an easy excuse to point to.
    2nd idea, do you have a sun roof. Any leaks or maybe left open over night?
    Tell them you want pictures if they open it up or peal back the materials.
    my2cents.
  8. bisco
    52,854
    hmm, kids dumping a bottle of water down the cooling fan vent might not leave any evidence. i wonder if it is sloped so that the water would reach the batteries? not out of the realm of possibility.
  9. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I went back and read your original post. Did the dealer actually open the battery case up and find water inside the battery housing? Or is he basing this on DTC recorded ? Or based on seeing evidence of water in the back compartment ?
    I did not see any mention of how the dealer determined there was water in the battery housing.
  10. The Battery Clinic
    The Battery Clinic New Member
    Auckland
    2001 Prius
    ICE here is short for Internal combustion engine. Water damage from plants in boot!! That's a tall one to spin. Hybrids are built tough. Always follow these procedures. 1) Make sure you have a good strong 12 volt battery. If in doubt connect another in parallel with battery Jump Leads. 2) If it still don't start then attention should turn to the main hybrid battery. Make sure this battery is charged up ie has enough voltage what the voltage is depends on the model and make. 3) You don't have to replace. reconditioning and a Power Jockey works well and is miles cheaper.
  11. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Of course in the end, you could just convert to PHV via a kit for the same cost...
    But others are right - Toyota will pay - just go to a different dealer...
  12. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Welcome aboard NZ battery. This is the source of the "ICE" info I posted last nite.
  13. jaegerd
    jaegerd Junior Member
    austin
    Okay, I have a lot to look into. First of all, my kids are teens and if they were dumb enough to pour water into a vent at this age, I have a bigger problem on my hands than this whole battery thing! I spoke with the dealer today, the service manager. You are going to love this.....he said he would NEVER put ANY liquid in the back of a Prius. Okay.....that could be a problem. Corporate called, the assistant to the case manager, and said they would not be calling me until tomorrow. Service manager called again and said he got a field manager (?) out of Houston to come up to look tomorrow for a "second opinion." Dealer where I bought it said to keep it where it is, I think they are co-owned. Service manager said he has a Camry for me to use in the meantime. I got the codes, but of course, left them on my desk in a lame attempt to get out of my office in time to pick up the Camry. There were 4 of them and I will post them tomorrow. I don't think there is a leak in the windows or hatch and no, the car does not smell funny. Well, actually it does, but I think that's a dog thing. There is no evidence of a leak in my car at all. The plants, I only brought that up because service asked me, as there were a few leaves in the back. No water. No smell. No fish. I will fight this until the bitter end and will not pay for a new battery. The manager said the casing was aluminum and not worthy of being liquid-proof. So there you have it!
  14. bisco
    52,854
    thanks jaegerd. this is a wild tale! aluminum would be waterproof depending on the seals where it closes. but we're talking a LOT of water here!
  15. V8Cobrakid
    3,790
    152
    i'm not saying C is your problem... just that it is a problem potentially at some time because it won't throw codes for it... off topic because i saw it on that list...
    i still think it's kids...
  16. V8Cobrakid
    3,790
    152
    oh... scratch kids... teens don't do that
  17. V8Cobrakid
    3,790
    152
    i got it!... check your windshield washer fluid... the rear washer line runs just around the vent and fan on the right hand side of the car.. it's a clear tube with no protection (on my genII it is.. i assume the same for genII too)
    if you put something heavy in or somehow pushed the right liner and somehow pinched the tube or something. if you're windshield washer fluid is low, it's because the reservoir is higher than that line.. so it all leaked out.
  18. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    This is beyond belief.
    Let us know what happens. Toyota should make good, unless they want another corporate black eye.
  19. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    This is long shot so forget about it for now. But if we are talking doggy urine and ammonia this has consequences for any brass (if any exists in the car - I do not know). It can crack it.
    {See Wikipedia "Brass" for photo of cracking}
  20. jaegerd
    austin
    no, they have never urinated in the car....I would have killed them by now. I do think the washer fluid is a potential cause. I still wonder about car washes when the water shoots up the bottom. Does anyone know if that could possibly get the battery wet? I run through a wash about once a week. Service guy says no, couldn't get the top wet, but I wonder....
