Hybrid Battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Iamjo20, Mar 28, 2014.
  1. Patrick Wong
    18,210
    6,517
    Here are two possibilities:
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Well, you can certainly trust me. I've been working on hybrids for over 10 years.
    I also started the local hybrid car club here in 2004 and have been doing public education about hybrids since then as well. I am well know and respected in the hybrid community.
    The good thing is that you are taking steps to educate yourself BEFORE you have a crisis. That way you have a plan when a problem arises.
    I'm happy to chat with you via phone if you ever need a little direction or have questions.
  3. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Ok I'm confused. Are you telling us that you've already had to replace the traction battery on your 2008 Prius at under 20k miles - and that it wasn't covered by warranty? Or did you not realize that the post of Eric's that you replied to was talking about the traction battery and not the 12V battery?
    52,730
    her first post was about someone else's low mile battery that had to be replaced. so she was concerned about the future of hers.
    Merkey likes this.
  5. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Thanks bisco. Yeah I understood that, but if you look at the post I quoted this has now turned into "and receive my money --argh. was not covered by warranty!". So suddenly it's starting to sound like a first hand case, hence my confusion.
  6. bisco
    52,730
    yeah, that was a weird one, hopefully, she'll come back and illuminate.(n)
  7. Iamjo20
    Iamjo20 Member
    259
    that is correct-not my vehicle----
  8. Iamjo20
    Iamjo20 Member
    259
    Thank you--I will keep you info--and may do that! :)
  9. Iamjo20
    Iamjo20 Member
    259
    Hi there--well, it was the 12V battery which had to be replaced on my vehicle, and No, I did Not reazlie that Eric was talking about the traction battery--and, not being totally stupid, but I do not know what the traction battery is--only know about the 12V and the Hybrid battery--
    Thanks!
  10. Iamjo20
    Iamjo20 Member
    259
    I guess I mentioned too many items--
    1. the 12 V battery on my vehicle did have to be replaced--was NOT covered under warranty
    2. the other question was simply dealing with the future life of my hybrid battery--and what I was told about other's batteries--
    TY!
  11. Patrick Wong
    18,210
    6,517
    traction battery is aka high voltage hybrid battery, located behind rear seat in large rectangular sheet metal enclosure, in the hatch area. It can be seen when you remove the folding hatch floor.
  12. Iamjo20
    Iamjo20 Member
    259
    Thank you for the battery charging info---can you also send me a visual of where this charging leads are to be placed? TY!
  13. Patrick Wong
    18,210
    6,517
    You need to either connect the charger to the dedicated positive jumpstart terminal within the main relay/fuse box behind the driver's headlight in the engine compartment; or else directly to the 12V battery located in the right-rear corner of the hatch floor. The former is preferable because if any doors or the hatch are open, that causes more battery drain. Please do a search for more info.
  14. Iamjo20
    Iamjo20 Member
    259
    Duhh--thanks!
  15. bisco
    52,730
    btw, chargers are for your 12 volt, not hybrid battery. you only need it if you don't drive more than once a week or so.
  16. Iamjo20
    Iamjo20 Member
    259
    LOL--THAT I did know :)
    My car is driven every week-just not that many miles---is a charger mainly needed when the car is not driven for a week or more?
  17. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Hi Lamjo. "Traction" just refers to a component that is used to provide motive power. So the high voltage battery is also known as the traction battery.
    Referring back to your concerns about battery longevity, let me keep it really simple with this summary.
    1. Doing low annual mileage can be bad for 12V battery (unless some form of external charging is used).
    2. Doing low annual mileage is NOT generally harmful the high voltage battery.
    3. One anecdotal case does not a theory prove.
  18. Iamjo20
    Iamjo20 Member
    259
    referring to
    #1. If the vehicle is driven each week, but not necessarily easy day, should it be externally charged?
    #2. gotcha! :)
    #3. TRUE :)
    thank you for being succinct and to the point
  19. Patrick Wong
    18,210
    6,517
    1. Yes, if you wish to maximize the service life of the 12V battery. If you are good with paying $300 every 3-4 years to have your local Toyota dealer replace the battery, then no worries.
    Iamjo20 likes this.
  20. Iamjo20
    Iamjo20 Member
    259
    okey dokey --thanks :)
    Now simply need to find out the correct way to attach the charger--
