Hybrid Battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Iamjo20, Mar 28, 2014.
  1. Iamjo20
    Iamjo20 Member
    259
    You have a reference on the two chargers you suggested?
    52,730
    the owners manual details the charge points under the hood.
    Merkey likes this.
  3. Iamjo20
    Iamjo20 Member
    259
    TYPO -- on my comment--mean to ask--do you have a PREFERENCE to the two chargers you listed? And, it appears as though it is better to charge under the hood and not in the trunk............?
    52,730
    it's easier to charge under the hood. the battery takes a bit of undoing to get to, unless you add a permanent lead. either way is fine.
  5. Patrick Wong
    18,210
    6,517
    The CTEK charger is the better of the two because it looks like you can select AGM as the battery type. An AGM battery needs a higher ultimate charging voltage than a regular flooded lead-acid battery.
    I listed the Schumacher to give you a cheap price point. If you can't afford the CTEK, the Schumacher is better than nothing.
    Yes, it is better to charge via the dedicated positive jumpstart terminal in the engine compartment. The negative charging cable would connect to bare metal, for example one of the nuts that hold the suspension strut to the body metal, behind the main relay/fuse box.
