Hybrid battery
Discussion in 'Prius c Technical Discussion' started by fahadw2000, Jul 1, 2019.
  1. fahadw2000
    fahadw2000 New Member
    Pakistan
    2013 Aqua
    I am not exactly sure what you are asking.
    The connectors which were connecting the battery pack were having signs of Discoloration in form of rust. But that issue was solved.
  2. fahadw2000
    Pakistan
    2013 Aqua
    I think techstream is better for the purpose instead of manually doing that, isn't it?
  3. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I think you need to pau someone to help with this tasks. It appears you need more time to come to grasps with the tasks at hand.
    fahadw2000 likes this.
  4. fahadw2000
    Pakistan
    2013 Aqua
    No, Import problems
    Yeah it does take time. But, to which specific thing are you referring.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    I mistyped that first sentence. I was asking if there was any discoloration ON the steel baseplate. A large area of discoloration is an inication that a module is leaking electrolyte. That creates problems for the battery, but will typically not affect voltage or current.
  6. fahadw2000
    Pakistan
    2013 Aqua
    For that I have to open all the cells and take them out, isn't it? If it is I will have to do that to see discoloration.
  7. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I mean, it appears this tasks is above your skill set.
    Y not get someone paid to do the job?
    You must not "forcefully" be a Diyer.
