Hybrid Battery
Discussion in 'Gen 2 Prius Technical Discussion' started by Scotcam, Aug 10, 2020.
  1. Scotcam
    Scotcam New Member
    Boston
    Hi All,
    I hope you are all doing well and staying safe. I am new to this thread. I currently own a toyota prius 2005 with 222k miles.
    Over the last week, the red triangle has appeared along with the traction light, brake light etc. The battery has also went from 4 or 5 blue bars to just 1 red bar.
    I purchased the BAFX OBD2 code reader yesterday and I was wondering what the best app is to use?
    I noticed that some people have used Dr Prius app and would be curious to hear what people thought of it/ if it gave them a good diagnosis.
    Thanks!
  2. AzusaPrius
    AzusaPrius Senior Member
    2,252
    942
    Download the app and try it.
  3. Scotcam
    Scotcam New Member
    Boston
    Azusa,
    I downloaded the app. I have attached my results below. If anyone could help with what it exactly means, that would be much appreciated.
    Thanks,
    Cameron
    52,786
    what is error code p3000? looks like a problem with block 3
    you might need tech stream for the sub codes
    Prodigyplace likes this.
  5. Scotcam
    Scotcam New Member
    Boston
    Thanks Bisco for the reply. It appears that P3000 relates to the battery control system.
    Yes I was hoping that I could just replace block 3 but I do not know if this is something that a lot of people have done. I feel that the car is probably a right off tbh if I need to replace the hybrid battery as it has 222k miles on it.
    I have been using the Dr Prius app which has been very helpful in determining the blocks.
    If anyone has replaced one of the blocks, it would be great to hear the process?
    Thanks again for all the help and advice.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Thousands of rebuilt battery posts. Start reading the threads.
    Unfortunately there all over the place. Wish they would have just a battery rebuild sub forum.
    use the search forum tab up top and search
    hybrid battery or battery or mini vci or techstream.
    2GenPrius and donbright like this.
  7. bisco
    52,786
    replacing a module is covered pretty well here. not too difficult if you're a decent diy'er.
    the complication comes with how thorough you want to be in rebalancing, and trying to reduce the times you have to slug the battery in and out repeating the process.
    i'd let it go, but this is priuschat. many here hoping for a half million miles, and some accomplishing it.
    according to other postshere though, the p3000 might not be a cell but an ecu, so i'd proceed carefully
  8. Scotcam
    Scotcam New Member
    Boston
    Thanks! Yes i will take a look at other forms and see what I can find out, I appreciate the quick response.
    Hi Bisco,
    Yes I agree. I actually tried to get a quote just for replacing block 3 and it was around $800 - $1000 dollars which seems really expensive. I will do a bit more research but unless I find a cheaper solution it is looking like I might get rid of it.
    Thanks!
    #8 Scotcam, Aug 12, 2020
    edthefox5 likes this.
  9. judot
    judot New Member
    Phoenix
    Hi Scotcam,
    I have a 05 Prius of 205K miles. I have replaced bad module before and it was relatively not too difficult as there are many youtube videos showing how to take out the battery pack and replace individual module. It would solve the red triangle problem but the issue is that the overall efficiency of the battery pack might not get much improvement and chances are you may need to do it again as another module breakdown would happen soon.
    I have experienced this scenario and so I am in the process of rebuild (replace and reconditioning) my battery pack. Keep reading other threads and youtube showing how to proper repair and reconditioning a battery pack. It is not terribly difficult but very time consuming as there are many module and each module has to be cycle several times.
    Best wishes!
  10. AlexY
    AlexY Member
    163
    45
    UK
    In my 2001 I've replaced bad cells twice with about a year gap, 2006 model got new cell this year, so far it was single cell failing in every case.
  11. MilnerMR
    MilnerMR New Member
    South America
    Hi guys!
    Does anybody understand these values?
    I was checking if a needed to change some modules because the red triangle appeared a few days ago. However, I don’t understand what’s happening, these -320.2 means that those blocks are all dead?
  12. AlexY
    AlexY Member
    163
    45
    UK
    It was giving correct reading anytime before? This readings looks like HV ECU fault, but it also can be bad Bluetooth OBD adapter.
  13. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    It probably means the No. 2 frame wire is corroded and/or broken. There may be corrosion also at the battery ECU connection where the frame wire plugs into it.
